SOURCE: Touchscreen buttons not working
the flexwire is the problem of your camera, the touch screen connection is already cut..go to a service center for replacing or repairing the flexwire...is not easy for repairing that if you are not a technician that wiring is like a strand of hair that why is difficult to fix but in our shop we modified that and become more durable than the original...
SOURCE: HTC Touch screen not responding!
This is a common problem with many touch screen phones. There are about three reasons this can happen that I know of:
1. Hardware issue. Needs to go in for repair. Hopefully under warranty still.
2. Needs to be re-flashed with the OEM ROM. This is not likely, since you've already Hard Reset, but worth a try.
3. The EASIEST and FIRST thing to check is to run a 'business card' around the edge of the screen between the case and screen. Dirt or other objects can easily get wedged into that area and hold the screen pressed down. This would prevent a press from any other area of the screen. Also, a screen protector that has shifted might cause this. Hopefully this is it, as it's a simple fix!
SOURCE: My touch screen is not responding
My touch screen has not been responding but my navigation buttons are working. I'm not able to check my contacts too.. .
SOURCE: Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
SOURCE: I purchased a NAVMAN S-150
I have the same problem, the s150 touch screen is pathetic, Got the same story from Strathfield Car Radio..it was normal and had it in for repairs twice when the screen went crazy with vertical lines, same fault both times. I went back to using my s50 and will sell the s150, it is a highly complex, very pretty lemon. They wont refund you or give map upgrades for inconvenience caused by their faulty product. To sum the s150 up. A truly Miserable experience. Rate it out of ten? its a minus.
Graeme
