Hello Liza's, if you do not have the remote control to control your DVD, from the front of your Sony, you can turn it on, open and close the DVD carriage, put it in Play and Stop it, nothing more
With almost any universal remote, you can manage the Sony DVD
I hope you serve my suggestion
Greetings Franco Dosil
Hola Liza's, si no tienes el control remoto para controlar tu DVD, desde el frente de tu Sony, puedes encenderlo, abrir y cerrar el carro porta DVD, ponerlo en Play y Pararlo, nada mas
Con casi cualquier remoto universal, podr?s manejar el DVD Sony
Espero te sirva mi sugerencia
Saludos Franco Dosil
https://www.sony.com/electronics/support/res/manuals/4447/d1526642f56f7d2c942c4598ea9add71/44474743M.pdf
SOURCE: Codes to program vizio universal remote to DVP-SR210P
0183,0188,0185. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
SOURCE: I need the code for my Sony DVD player model DVP-SR210P. If you can help thanks
Could be one of seven codes, so try each until one works.
20533, 21533, 20864, 21033, 21070, 21431, 21536.
One of these should work if set-up directions are followed correctly.
SOURCE: Code for Sony DVD player model DVP-SR210P using Vibe 5-1 universal remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
make spectrum do it ! you pay them enough ! its their responcability
