Hello Socorro, for what you are saying, your Pioneer is not ventilating the heat produced by the circuits, internally your TV has a series of internal fans, to cool the heat produced by the circuits
I suggest you communicate with a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Socorro, por lo que comentas, tu Pioneer no esta ventilando el calor producido por los circuitos, internamente tu TV tiene una serie de ventiladores internos, para enfriar el calor producido por los circuitos
Te sugiero que te comuniques con un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/290938192PDP42A3HD_US_0420.pdf
SOURCE: Letters in upper left hand corner of screen
You may find it in your "Menu" button on your remote, search for anything similar to "HD Logo" and turn it off. Failing that, make sure it isn't stuck on with transparent plastic, haha.
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
http://stores.ebay.co.uk/Plasma-Parts-UK
hope this helps mark doran
SOURCE: two years old, burners look
Randy, it sounds like the burner(s) need a good, thorough cleaning. Apparently some of the burner ports are clogged and the flames are not equal along the burner. If you take this one out to clean it, clean the other two, as well. It's a good idea to clean the venturi valves too.
Hope this helped you to troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Visit the site named 'Electro-help' for more
details. Click this link.
View it in 'Flip
card' option, which can be selected from the drop down box menu by the
[Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each
posts, both at the right and bottom, might help you to find the availability of
spare parts. There are more than 850
posts to different brand TVs now.
Sometimes you might get a solution to the problem to your PDP from here.
