SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu
picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box:
on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
SOURCE: Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
