The Canon Image Runner 2520 uses a DC Controller PCB assembly that includes the display card as part of the assembly. The part number for the DC Controller PCB assembly is FM4-2924-000. You should be able to find this part in the Canon Image Runner 2520 service manual or by contacting Canon customer support for assistance in ordering the part.
SOURCE: Copier Harddrive
Remove the rear cover. The hard drive is at the top, near centre. Disconnect the connector and remove the four screws. The hard drive can then be removed from the mounting plate. New system software needs to be installed if a new hard drive is fitted to the machine in order for it to operate. It will not function without a hard drive or the system software.
SOURCE: need user manual for image runner 5000
http://www.fixya.com/support/p189647-canon_imagerunner_5000_copier/manual-18713 here ya go, please give me good rating as far as being able to help you. Take care. :-)
SOURCE: Canon Image Runner 3570 Error Code Display E000019-0000
Canon Image Runner 3570 Error Code Display E000024-0001
Copier ask me to shutdown machine.Its going read for funtion and after print 0ne copy,its repet error code display E000024-0001.What is this ?
SOURCE: Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
SOURCE: I have a Cannon 2020i Image Runner, we had thunder
You need to remove the back cover and on power supply pcb there must be fuse. I belive glass fuse 5X20mm, not sure for how much A.
For service manual and board circuit send me mail on [email protected]
