I replaced the spool, but still keeps feeding out line
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
SOURCE: 18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
SOURCE: Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
