SOURCE: Royal alpha 601 sc cash register
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
SOURCE: I need free manual for Royal ER 145. Recently
Here Goes Program 2 position - enter 102420 att/total key - program 1 position enter o in the departments as non tas enter yy mm dd (09 04 23) hit charge key
enter time hhmm (1500) military time hit xtime depress amout tend key turn off and on and maybe will work for your child...Good luck......have fun
SOURCE: Royal Cash Register ER 246 Manual
http://www.the-manuals.com/
hope is right.
Testimonial: "Did not have Royal ER-246 manual :("
