SOURCE: punch software home design
How did you do it before? Please give more details so that we can troubleshoot this issue..
SOURCE: Home Design 3000
The textures going to the sky / grass is a classical issue of a videocard problem
Try to follow these steps
1 - Go to the website of your video card manufacturer (it can be found using any search engine and the manufacturer's name and the card model). Look for downloads, and see if you have the latest version of driver software for your model of video card (you can find your current driver's version at Video Settings->Advanced->Adapter). If there is a newer one for your card and the operating system, you are running, download and install it following the manufacturer's directions.
2 - Click on Start->Run and type in "dxdiag", and click Run. The DirectX diagnostic will run, and tell you what version of DirectX you are currently using. Go out to www.microsoft.com/directx, and see what version is current. If your version is not current, read the install instructions, the system requirements, and the FAQ. It is recommended that you download the latest version and install it.
3 - Try to slowdwn the videpcard accelerations: To slow down accelerations--> click on an empty part of the windows Desktop, click on Settings->Advanced->Troubleshoot. Back the accelerations slider to the left, one level each time and see if the problem dissapears
SOURCE: Punch software- Landscape, Deck--3D feature pitched black
Read the design software's readme and system requirements. If that doesn't help: Ask. Punch.
SOURCE: punch software 5in1 Home and deck Design
Did you try running the program in "Compatibility Mode"?
Right-click on the shortcut
Select "Properties"
Select "Compatibility"
Check off "Run this program in Compatibility Mode for"
Then chose Windows XP SP3
Keep trying different options until the program responds the way it should.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
