Exercise & Fitness Logo
Krown RR33 Posted on May 25, 2019
My wife proform ifit elliptical screen is cracked and I did know till she turned it on. Know I have a $800 dollar machine she can't use. What can I do.
johobikes
Level 1:
Habit-Forming:
Scholar:
  • Contributor 56 Answers
  • Posted on Jan 10, 2020
johobikes
Contributor
Level 1:
Habit-Forming:
Scholar:
Answers
56
Questions
0
Helped
30216
Points
80
Front page of the manual has a contact for the manufacturer.
Warranty is on the back page.
Elliptical consoles come as completes, no harder to install then the original assembly
5 Related Answers
Anonymous
  • 103 Answers
  • Posted on Nov 13, 2009
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Anonymous
  • 48 Answers
  • Posted on Nov 23, 2010
SOURCE: I have a used ProForm 900 Elliptical. It works
hi
it uses eddy mechanism
check very carefully eddy magnet probably one of the plastic adjusters broken)
Anonymous
  • Posted on Apr 10, 2011
SOURCE: I have a Proform Stride
The belt loops around the grey cover that says proform 825 on the inside outer edge
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Apr 05, 2012
SOURCE: Proform elliptical 10 ze won't turn on
Dear Sir:
1) Replace by good batteries new one 2) Clean very well the contact with contact cleaner spray from R.Shack.
2) Turn the flywheel untill passing for the reed switch,and adjust it see the diagram attached, and ready.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on May 03, 2012
SOURCE: Proform 480 LE Elliptical screen does not work, but everything else works properly
5_3_2012_7_37_07_am.gifclean the contacts batteries for OXIDE, very well, see if some wires is loose.
Try to RUN the software calibration for diagnose and troubleshooting.
1helpful
2answers
I purchased the preform 1110e ellipitical it has the monitor for ifit my wifi will not pick up the connetion to the ifit on my ellipitical why
https://ifit.zendesk.com/hc/en-us/articles/201881134- WIFI Requirements for WIFI Built in Machines
here are some requirements for your machine to connect to WIFI. If you are having connection issues, please read through these requirements, and tips to troubleshoot and resolve your issue. If you are unsure of any of these settings, please refer to your ISP(Internet Service Provider), or router manufacture for support.
  1. Broadcasting in 802.11 G/N
  2. Broadcasting Publicly
  3. DHCP Enabled
  4. Mac Adress Filtering Disabled
In most cases, the main cause for your machine not to connect is an incorrect WIFI password. If you have not changed your password, it is usually located on the bottom of your router.
Setting up iFit with built-in WiFi Setting up iFit with built in WiFi
This console is very easy to set up and use. If you have a router that has the WPS feature, just press the button on the front of the router then in the information mode of your equipment choose the WiFi WPS setup.
Set your machine to display the Information Screen. On a treadmill press and hold the STOP button as you place the magnetic key. On a bike or elliptical check in your owners guide but you ususally press and hold the "hamburger" or calorie button.
Use the arrow keys to select WiFi normal then press ENTER.
This screen reminds you of the WiFi setup card that came with your equipment. It will be needed to enter a password for your router.
Select your router from the list.
If your router needs a password enter it using the overlay card to find the correct buttons.
You will be presented with instructions to go to ifit.com/connect to enter this token. You must log in first.
Enter the same token you saw on the screen and your equipment will be connected to iFit.
You can watch a YouTube video here.
good luck
1helpful
Proform elliptical is making a clicking noise on flywheel
My 3 month-old Pro-form RE19 developed a similar clicking/clanking noise accompanied by an intermittent rumble, all coming from the flywheel. Phone support listened to it and ordered a replacement flywheel under warranty. Installer is supposed to come swap out the parts.
2answers
How to the update ifit firmware
go to www.ifit.con directly
sincerely.
ernesto cuadra
managua,nicaragua c.a.
Ipod speakers do not work on the Proform 490c treadmill
To use the music port for iPod, you need an iFit Universal iPod Connector To purchase an iFit Universal iPod Connector call 1-800-533-1333
1helpful
2answers
I have an older proform elliptical and the battery cover cracked.
Go to FitnessRepairParts com and type in your exact model number in the search box at the top to view the parts list for that model. You may be able to find a cover there. Or you can contact support if you can't find your exact model number, they are very helpful
10helpful
MISSING SAFTY KEY CAN YOU BY PASS TILL REPLACED
ive got given a 625 pro form treadmill and the key is missing i know i can order one but for now i just want to use it is there any way of bypassing the key so i can use it. thanks in advance
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
