SOURCE: MSW3517 Book inside
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number.
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
SOURCE: locked out of my cs2 safe
If you registered your safe with the manufacturer they will normally let you know your combination if you have registered the safe.
If not you will need the serial number on the side of the safe and you will need a notary stamped paper explaining you are the rightful owner of the safe.
Costs will apply to the Notary and possibly from the manufacturer.
Testimonial: "thank you very much your help was excelent "
SOURCE: i put parental lock on our LG lcd tv. I entered a
When the TV asks for the code, put in 7777 to reset the code.
Do not make the new code 7777!
Good Luck.
Testimonial: "Spot on solution and very quick response. Thanks So much!"
SOURCE: Just installed a Schlage secureKey
the first thing to check is to take the hardware off the door and check the lock cylinder with the key and make sure the key works the cylinder,, lots of times the tail piece is in the wrong position and will not allow the lock to turn. also - sometimes the latch and the lock are not lined up and bind, preventing the cylinder from turning.
but maybe the cyclinder itself is keyed wrong and if you take it back to the store where you bought it you should be able to swap it out for one that works,, install that one and all should be good.
c...
