Frozen Food
Can Be Cooked
In The Air
Fryer
All frozen
foodstuff meant
for baking in the
oven cooks perfect
in the hot air food
fryer.
Frozen fries,
nuggets, fish sticks
etc.
A quick Google search says that you may be able to cook a frozen meal in your air fryer. I suspect the make and model of your specific unit would be a factor as well as what meal. Here is a link to a video (I did not watch it) How to Cook Frozen Food in the Air Fryer - YouTubehttps://www.youtube.com/watch?v=ruOR5s3zH6I https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=2ahUKEwizh86MzbfiAhUuvlkKHevZCGEQFjABegQICRAK&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DruOR5s3zH6I&usg=AOvVaw2k4uR6drZXFWz0xi_eS2kz
SOURCE: sanyo microwave EMS667W, diff high power ratings
A couple of things: If the dinner is in an aluminum pan, DON'T put it in your oven. Typically, high power units need about 3-5 minutes to heat a dinner so you should have heated it through. The power default is usually full power. Usually, there is a minutes button that should give you incremental minutes for programming.
Try using a standard nonmetallic cup (beaker) and fill it with water. Heat for 2 minutes. The water should be boiling hot. If not, your oven is not doing it right.
SOURCE: we wre cooking with are
Continenal Electric model #ce23391 used once and it quit working , any suggestions
SOURCE: low power
Check the power output. Most are adjustable. With the microwave on, and cooking something, see if it is on 100%. If not, adjust it with the keypad.
Regards, --W/D--
SOURCE: When I was cooking dinner and went.. when I was
did the clean lock get pushed to lock it ,let the oven cool down and it well unlock. it should open at about 100 degrees
