It looks to line up exactly with the ground in the upper outlet in my 2-outlet plug. I am a little afraid of plugging it in without knowing if that is "as designed" and safe.
SOURCE: 3 prong outlet/4 prong plug
Hey pcote
The 4plug wiring is for satifying the electrical code (i think 2002) so your wiring need upgrading. The wire on your new unit should be as below
black and red - hots,
white - neutral, green - ground.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You could simply connect only the black, red and white for your 3 wire system. Often new units have an internal metal ground strap (green wire) that can be tied to the white (neutral) in a 3 wire system.
Regards
SOURCE: Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
SOURCE: Connection
the green wire will attach to the dryer cabinet. The white wire will attach to the middle and the other two(red& black) will attach to the outside of the terminal block.
Good Luck!!
SOURCE: The power outlet fuse keeps blowing in my 1997 Lexus ES300
the 3 cla charger might be your problem
SOURCE: Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
