SOURCE: Internal Server Error 500
Start Internet Explorer. 2. On the Tools menu, point to Pop-up Blocker, and then click Pop-up Blocker Settings. 3. In the Address of Web site to allow box, type http://v5.windowsupdate.microsoft.com, and then click Add. 4. Click Close to close the Pop-up Blocker Settings dialog box.
SOURCE: Proxy Error, the proxy server
This appears to be an issue with the ISP's equipment and/or service provision. You will need to contact the ISP directly (the company that provides your internet/email functions) to report the problem and request that they correct it.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution.Thank you for using and rating FixYa!
SOURCE: HTTP 500 internal server error while accessing yahoo account
Check your computer for malware, because you should be logging on with https, and not an unsecure connection. Free options i suggest are avast antivirus, www.avast.com, and ad-aware, www.lavasoft.com.
Additionally, you may want to see if you have the same error with a different browser, such as mozilla's firefox, www.firefox.com
SOURCE: win 7 refuste installation of a modem !!!
Change User Account Control Settings to lowest setting (just type those words into the box after pulling up the start menu - microsoft icon in lower left hand side).
Set it to low.
Reboot if needed.
PS - if you are running and sofware, run as Adminstrator
SOURCE: I can't sign in Y!M
Checking virtual IP servers...
[VIP Raw] Connecting to Virtual IP server 98.136.48.32...
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [FAILED]
*** 'COMPONENT_TYPE_WININET' value: '12017' *** [PASSED]
[VIP Raw] Sending HTTP request to the server... [PASSED]
[VIP Raw] Receiving response... [PASSED]
[VIP Raw] Checking HTTP response code... [PASSED]
[VIP Raw] Parsing connection server IP address... [PASSED]
[VIP Raw] PASSED *** 67.195.186.245 ***
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [FAILED]
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0203' ***
[CS Raw] Connecting to connection server port '80'... [PASSED]
[CS Raw] Sending port check command... [PASSED]
[CS Raw] PASSED
Checking login servers...
[Login] Resolving host name login.yahoo.com... [PASSED]
[Login] Connecting to login server 69.147.112.160... [FAILED]
*** 'COMPONENT_TYPE_WININET' value: '12029' ***
[Login] FAILED
