The sweeper PTO drive has just stopped - my instincts are that it is electrical
SOURCE: I have a Cub Cadet 1250. The PTO suddenly stopped
Look at www.cubcadet.com. There under parts you should find an IPL for your mower. You will need the model and serial number from under the seat to get the information. Look under the electrical for PTO.
HTH
Good Day.
SOURCE: require an electrical circuit diagram
Call Countax on 01844 278800, they're customer service is usually good at supplying this sort of info. Ask for a parts list and user manual while you're at it.
SOURCE: the sweeper shaft on my countax lawnmower keeps
I have a countax E36 which had the same problem. If you remove the axle of the sweeper you will most likely find the square axle damaged at the end. I ordered a new one from cyriljohnston.co.uk and had it over night €28.00 all in. When replacing it, you may need to install washers to take up the wear on the bearing eyes ! Hope it works for you
SOURCE: I am working on a
The most reliable place I know of for a complete electrical schematic is available for a fee from
www.alldata.com
This is a website many professional shops use to get their information, schematics, and diagrams, as well as step by step instructions. Here is a link to buy a manual that may be cheaper than using alldata. They want $39.95 plus shipping for this USED manual.
http://www.auto-repair-manuals.com/GMC-1980-MediumHeavy-Duty-Truck-Factory-Wiring-Diagrams.html
Here is their description of the manual;
This manual provides Wiring Diagrams for 1980 Medium and Heavy Duty Truck Models.
Contents: Cab, Engine and Chassis Wiring Diagrams for
SOURCE: PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
