I can see where the hook goes but what about the other arm on the reel. Would it be too much to ask for simple installation instructions for a clothesline.
SOURCE: installing the belt around the dryer drum
you will have to take the drum out to see where the tentioner was inserted , it is in line with the motor pulley, should be a couple holes it fits into.
putting the belt on is easy , with the lined side of the belt down on the drum take the slack at the bottom with a finger holding the belt , move the belt toward the tentioner until it touches the tentioner pulley
then with your other hand help bend the tentioner pulley with the belt on it until you can touch the motor pulley with that finger , slide it off your finger onto the motor pulley and the belt is on.
let me know if you have any questions.
Phil
SOURCE: I pulled the paper feeder
Another of the HP disposable line - they aren't supposed to be fixable because it's cheaper to replace them. No service manuals available, sorry. But from what you describe it's the roller pressure spring - the spring is there to keep the roller pressed on the paper jam sensor.
In most national parks you are not allowed to string a rope to a tree therefore a clothesline can become a very handy piece of equipment. You should set them up out in the sun to let the clothes dry quickly.
