Hello Crystal, I do not understand your question, what do you want to do with the Pioneer CX4000?
Indicates brand, model and type of equipment that you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Crystal, no entiendo tu pregunta, que es lo quieres realizar con el Pioneer CX4000 ?
Indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: pioneer 4000 making it work without brake on
Press setup on remote control.
After enterning the setup screen:
1) Select the "Language" tab
2) Once in the language selection menu, press: 543210.
3) A menu "secret" screen will appear, select the "Hammer and Screwdriver" button
4) Select "Brake Override"
5) Select "On"
6) Press "Setup" on the remote again to exit screen.
