Have tried every button
If the drive button marked, eject is dead here are the possible.s
1:drive is dead. (called bad)
2: cables to it fell off.
3: a disc inside is broken or label fell of jamming it. the paper clip eject now works.
google finds 1000s of web sites showing the magic tiny hole
https://www.geeksinphoenix.com/blog/post/2010/02/13/How-to-manually-eject-your-computer-CD-DVD-drive-tray.aspx
you posted to Computers but is some rare TV not sold in USA
want to see one, but non here.
moved.yah
SOURCE: DMR-EZ475V DVD Recorder
ive had this in the work shop befor the cogs can come lose inside the machine if your handy with a screw driver unplug from the mains and take the top of the machine and see if anything has come lose, 50% of the time you can fix this yourself if not you would have to contact panasonic and get them to send a engineer out to you.
SOURCE: Disc won't eject, stays in "RECOVER" mode
I have a panasonic DMR E-60 and had the same problem. What I did was remove 2 side screws and 3 rear screws and lifted top cover off. Then if you are facing the front of the unit to the right of cd unit there is a little nipple that locks the mechanism. Push that in, which would be to the left if your facing the front of the unit. Then press the eject button. Mind you it must be plugged in to power. Be careful not to touch any of the green boards or metal. Hope I was clear. I sent it to panasonic but they wanted 40. just to look at it and up to 140.00 to fix it.
SOURCE: problem ejecting dvd from side panel 32" dvd/tv conbo
Either the drive belt for the drawer transport is worn out or the drive pulley has a crack in it and cant drive the belt. Sounds like a trip to the service shop is in order unless you are into taking it apart and investigating yourself. Belt will cost about $3.00.The drive pulley can usually be carfully glued.Making sure not to get any glue into the motor.Hope this helps.
