Question about The Watches
How do i eject a dvd
Cannot find the right button
How to adjust time
Hi rina15luigi,
You can adjust the time your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Apr 11, 2011 | Timex 1440 Nylon watch
Tip
How to set/ change time on Polar F6.
Having trouble setting the time with your Polar F-Series watch, here is simple quick step-by-step guide to follow.
First know your buttons:
upper right - Scroll
lower right - Scroll
center right - choose
lower left - reverse/ back/ stop
upper left - light
#1 - Push the center right button (exercise will appear)
#2 - Push the upper right button (settings will appear) use the upper right or lower right buttons to scroll if neccessary
#3 - Push the center button (a menu will appear)
#4 - choose Watch, use the upper right or lower right buttons to scroll if neccessary
#5 - Push the center button to choose watch, once highlighted
#6 - use the upper right or lower right buttons to scroll through the watch menu
#7 - Choose Time
#8 - Continue to use center button and scroll buttons to choose and set.
Important button to know - the bottom left button is a reverse button. Make a mistake, just tap that button, keep tapping to go all the way back to the main menu.
on Dec 22, 2010 | Polar F6 Wrist Watch
Set time
Hi wimberlf,
You can easily change the time of your Timex watch by following the steps below.
Hope it helps.
Feb 27, 2011 | Timex 1440 Nylon watch
I can't change time on my Polar F6 - I can see a lot of other people having the same problem. And please - dont tell me to watch chapter 5 in the manual - I have red it over and over again. It doesnt make...
The buttons on the right (in the pic) or while facing you are the way into the menu's.
#7 - Choose Time
Hello ,,, I changed the battery in my Timex Indiglo and now just the light is working but not the minute hand or time hands. How do I fix this I have tried two batteries already?
Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
Jul 23, 2010 | Timex 27191 Wristwatch
How to set to 24hr mode for timex 1440 sports
Setting My Timex 1440 Sports Watch (4-button)
8. Press bottom left button, time format flashes ( now it can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
Feb 04, 2010 | Timex 1440 Nylon watch
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
SET THE TIME
: 1. With the time and date showing, press the top left button. 2.Press the right top button (this sets seconds) 3.Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm). 4.Press the bottom left button, minutes flash. Press the top right button until correct minutes. 5.Press the bottom left button, month flashes. Press the top right button til correct. 6. Press bottom left button, date flashes. Press the top right button til correct. 7. Press bottom left button, day flashes. Press right top button til correct. 8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished). To turn off the chime and alarm, press the top right button repeatedly until the CHIME or CH symbol is gone, then press the left top button. Repeat for alarm but watch for the bell icon or ALARM or ALM to disappear, then press the top left button.
Feb 16, 2008 | Columbia All Sport watch
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Apr 02, 2007 | Kenneth Cole RK5034 REACTION
Watches Logo
Top The Watches Experts
vince
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
