SOURCE: air filter
Is your set under warranty? If not, bite the bullet now and get the service manual - you will need it sooner or later.
Whether there is a way to reset the warning or not, a solution is
needed for the problem of restricted airflow and you will need to take
off teh back panel and blow out the dust using compressed air and while
your in there, look for any filters in front of the fans.
SOURCE: Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
SOURCE: Air Filter Waring for Panasonic PT-43LC14
I received the Air filter warning twice. I removed the back panel and used a HEPA (Shopvac) vacuum to clean the exbosed back and removed the sanp panel and cleaned the front. I did not remove the front bulb panel underneath the snap cover. Never found a filter and I have this model number. The warning has not come back so far.
SOURCE: Air Filter and reset the timer settings
go into the menu. it should be in the same menu as the lamp timer. as for cleaning the filter, use canned air.
SOURCE: light engine
hi there sorry for the late post i am actually new to here so thats why this is such a late response i too have this same problem this specific unit has 3 air filters in it all located on the projection unit which needs to be removed to remove the projection unit you first mus take the back panel off then remove the ballast cba next you ned to remove the tv/tuner unit and finally the projection unit can be removed its over on the right you will notice it very easily there is a rather large fan connected to it and once youve got that out carefully clean the 3 filters on the unit replace and you should be good to go this is coming directly from a service manual if any one needs the manual go ahead and pm me and i will get you the manual
