SOURCE: switching from pulse to tone
1)Make sure the phone is OFF (not in TALK MODE) 2)Press and hold the PROG buton until you hear a beep. The TALK button will flash while in this mode 3) Presd the TONE (*) button to select Tone Dialing or press the PAUSE (#) button to select Pulse Dialing 4) Press the PROG button again. The unit beeps to confirm.
SOURCE: DVD Audio Output Stops
Hey Kelby,
I've had a similar experience where a DVD movie would be playing and suddenly my Denon would just shut off, I later discovered that my rear speaker cables were not correctly installed in the back so the reciever recognized it as a short and would just shut down. Just make sure your rear speaker cables are correctly installed (right to right and left to left and with correct positive/negative placement) and see if it still does it. If it's still happening, then I wouldn't know what it is. Good luck.
SOURCE: car stereo wont work
Check all the connections with an analogue multimeter set to 12 volt dc.You should get fsd at all points. There is no doubt that you have an intermittent fault on the wiring.However, there is a slim possibility that this fault may, in turn, have caused damage to the clarion.If you cannot find a fault on the wiring, then consult a repair manual (available to download) to see whether or not there is a fuse inside the clarion. If there is one fitted, check that to see if it is blown. If thate above does not sokve the problem you are welcome to email me for further help on [email protected]. But I think fokkowing the above advice shoukd solve you lack of sounds in your car. All the best
SOURCE: I have a panasonic KX-TGA101s
press menu
press down key arrow until "Set tel line"
press menu for OK
press menu again for "Dial mode"
Select "Tone"
Raja Thurairajah from Canada
