SOURCE: Code Number for Remote Programming
Here is the link for the 8300 user manual if you need it; http://www.cox.com/support/digitalcable/dvr/pdf/SA8300HD%20connects.pdf here is manual for the dvd player http://www.yamakawa.it/dload/2xxenglish.pdf Not sure but try 438 or 445 as a code for your dvd, 445 most likely to work. (here is the link i got that from); http://dogbytecomputer.com/codes.htm#DVD%20CODES if this doesn't work then find a universal remote that you can get hold of easily near you and tell us the model number, we could probably tell you if it will be compatible with both machines and what the codes are. Hope this helps :)
SOURCE: code button
SOURCE: Converter box remote will not program
i have a admiral tv and i'm wanting to program my remote that goes to my converder box to the tv is there anyway i can do that?
SOURCE: Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
SOURCE: 4 digit code for handheld remote control to program a Crest Universal remote control
and on Strong SRT 6500 code? Thanks
