SOURCE: rainbow e series vaccum/scubber
If you are talking about the hard wood floor brush you hook it at the end of the one slightly bent wand. Look at the end of the brush that you would hook to the wand. In the circle opening there are two slits. On the end of the wand there are two bumps. You need to line them up, push the brush on then twist it around so it stays on. then you attach the straight wand to that and the other slightly bent wand at the other end of the straight one. It will go like this Wet hose, slightly bent wand, straight wand, slightly bent wand, and floor brush. I hope I helped. Leave the basin empty. put your water or cleaner on the floor scrub it around then turn machine on and suck it up.
SOURCE: changing the filter in Rainbow e series
Some of the e-series has a corrugated filter in the top section. To get to it, remove the clear plastic panels that are the sides. Most have 3 screws on each side to move, then the top half will come loose. There also is filter on the back, there is a door to remove to get to it.
SOURCE: Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
SOURCE: i need to know how to clean the hoses on a rainbow
take the hoses completely off and then pour water down them.
SOURCE: RAINBOW E SERIES REPAIR MANUAL
Hi. I found it on amazon, here: Amazon com rainbow vacuum manual. I hope I have helped. cheers
