SOURCE: Blinking green timer light and fan turning on randomly, now no power at all
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
thanks
scott
SOURCE: clock works fan turn on but no airflow and time cook, reheat and surface lights do not work
Test the high voltage capacitor,
the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed
discharge before testing, or you risk to get electrocuted, even if
power is off. Capacitors can get discharged by shorting their two
contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
SOURCE: Sharp microwave R-520L -- I just finished cooking
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101;'l';l
