Computers & Internet Logo
Posted on May 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Exide g1-12-775b how can i set to 240vac 1 phase
Ernest
Level 3:
Master:
  • Exide Master 489 Answers
  • Posted on May 24, 2019
Ernest
Exide Master
Level 3:
Master:
Answers
489
Questions
Helped
183698
Points
2971
Https://www.exide.com/en/documents-resources?search=Exide+g1-12-775b+&type=All
Please, use the above link to contact the manufacturer. The requested model installation manual is not online. The correct jumper settings on the transformer may vary by model. An incorrect setting could damage the equipment. The contact information on the website may be helpful.
1 Related Answer
Gene Haynes
  • 5391 Answers
  • Posted on Oct 23, 2012
SOURCE: 240vac timer load in and 2-240vac individual loads out. Color wires for #'s 1-6 on my timer
10-22-12
Intermatic ET1125 240Volt, two independent circuit Wiring shows on following link: Wire colors can vary. 240Volt line can be black-white, or red-white, or black-black. Non-code wiring can be white-white.
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html#1125
I have no idea what color wires you have.
Add a comment and include photo and more information about your wires.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
2answers
I have a Dayton Electric Motor Mod. 6K610E Is this a Single or Three Phase Motor
single phase 240VAC. data late will have info. 3 phase usually has 12 leads.
tip
Generator Not Producing Power ? Stator Winding
There are 4 requirements that have to be met before a generator is able to produce power. Due to number of questions that have been asked, a Coleman PowerMate 1500-1850 with a Briggs and Stratton Engine will be used here.
1) The Engine has to be turning at correct speed
2) Field Winding (Rotor) on the alternator must be energized
3) AC Winding (Stator) must create a voltage in presence of magnetic field
4) Output passes through Safety Devices before it reaches an outlet.
This Tip will cover the Stator Winding.
The stator winding is the winding that is around the outside of the rotor. It doesn't usually move. Previously, the alternator design was called a revolving armature, in which the field was stationary (outside), and the stator (armature) was the rotating member. This quickly was replaced, eventually, by the revolvingfield configuration, since the brushes carry a relatively small DCcurrent, rather than a larger AC current with destructive arcing. Brushes were prone to failure due to high wear.
In the revolving field architecture,there are primarily 3 types of alternators: Single Output, MultiOutput, and MultiPhase.
The single output alternator is just that, it outputs a single voltage. Typically, it will be either120vac (60Hz), or a single phase 240vac (50Hz) depending on the country it was bought in. The stator winding of this kind of alternator has only a single winding, with 2 wires coming off of it. One of these wires goes to the neutral bus for the outlets, the other wire goes to the circuit breaker, and the other side of the circuit breaker goes to the outlet. Disconnect both of the wires, and use your multimeter to check the continuity between them. You should have continuity here. Also check each wire to the frame of the alternator, there should not be continuity here though. If you don't have continuity between the wires, or if you have continuity between the wire and alternator frame, then you have what is called a grounded winding. This will have to be addressed by a motor shop, or replace the stator in its entirety. It is generally more cost effective to replace the generator though. Remove and sell the copper wire, and use that money towards a replacement generator.
Multiple Output alternators are usually found in the next step up from "bargain" generators. These usually will have an output of 120/240vac, and likely a low voltage battery charging circuit as well (12vdc being most common). The stator for these is checked in the same way as a single output, with a caution on the low voltage winding. On the low voltage winding,there will be a single diode (called half wave rectification) or a full wave rectifier (2 diodes) connected to the windings. You must disconnect at least 1 wire from the diodes to check the windings, and both wires to check for continuity between the windings and the frame of the alternator. If you don't disconnect the wire(s), the 1 way nature of the diode will indicate no continuity when there should be,and may cause you to not see continuity when there actually is (to the frame).
If the low voltage winding is open, the generator is still usable for the 120/240vac features. You just won't have benefit of the low voltage battery charging circuit, which is actually a very poor charger to begin with.
On a 120/240vac alternator, there may also be a switch that turns the 240vac on and off at the receptacle. This switch is put here so that the 2 120vac windings can be put in parallel for greater current capacity if 240vac is not required. If you have 120vac, but not 240vac, and the circuit breakers are not tripped, this switch is likely the culprit. It is just a double pole double throw switch that is easily replaced with one of the same type, and same or higher current rating. Never switch from 120 to120/240vac or vice versa while the engine is running. To do so invites winding damage due to arc-over, and may damage any devices that are connected from the voltage spike.
MultiPhase alternators are nothing more than single output alternators with a twist. Rather than having a single winding, there will be 3 windings, with a 120 degree phase separation. The in phase neutral wires will all be tied together, but the phase outputs will be separated, and connected to the receptacle in a specific order. This is called a Wye (Y) configuration. An alternate configuration is when the windings are all connected to each other, end to end style. The junction of each connection is then brought out to the receptacle. This is called a Delta configuration. Three phase / multiphase alternators will not be discussed in depth here as a much higher technical knowledge will be required.
As far as the stator winding goes, that is it. If you have continuity where you should, and don't have continuity where you shouldn't, the stator winding is likely good. As mentioned, if the low voltage battery charge winding is open, but not grounded / shorted to the frame, the primary function of the alternator is still usable.
If your checks of the stator are good,time to move on to the next tip.
Output and Safety Devices
on Sep 24, 2010 • Electrical Supplies
Www eemaxinc com support
My limited research indicates this heater is designed for USA electrical systems. That would mean single phase, 240/208 volts, 60 Hz. The drawings I reviewed shows a 2 pole, 240 volt breaker feeding each heating circuit. That means no "neutral wire" goes to the heater and therefore no 120 volts is needed. This is good. Kenya's system is single phase, 240 volts, 50 Hz. The heater should work reasonably well on the African system. Connect the power just like you would in the US.
2helpful
7answers
I WANT TO CHECK THE MAUFACTURING DATE OF EXIDE BATTERY MFG CODE 2 BO S.NO. 61610
2B0
2 stands for factory No.2 of Exide
B stands for FEB.month like A-Jan,B-Feb,C-March.....
0 year 2010, eg: 1: 2011,2 : 2012, 9: 2009
I need a wiring diagram for a three phase paragon timer model number 8145-20.
Paragon 8145-20 is a 240VAC (2 phase) timer. I doubt you will be able to find a 3 phase type timer.
I would suggest you use this timer as a control and purchase either contactors or relays rated to handle the 3 phase load.
I just bought a jp328sfss and need to know how to wire it to the breaker panel the way it is wired now it only heats water to 120 degrees F the handyman that hooked it up said there was no way to wire it...
It sounds like you better be careful for starters. I also suggest your handyman sticks to painting. In older homes a 208/240 circuit onlt had three wires. New construction and remodeling requires a four wire system. Per code, a black wire is 120VAC, and a red wire is 120VAC. In a 240VAC circuit they would be called L-1 and L-2 respectively. In order to provide 240VAC they must be on seperate phases. The bare wire in your bundle is the ground wire and is at the same potential as neutral, or the white wire in current four wire systems. If you know how to use an electrical test meter, you should show 120VAC from black to bare copper, 120VAC from red to bare copper, and 240VAC from black to red. If this is not the case, I strongly suggest you have an electrician come in and take care of it in your breaker panel. *****Electricity is nothing to fool around with if you are not absolutely sure you know what you are doing. A loose connection, a wrong connection can result in fire, serious injury or death. It's worth a service call to a licensed electrician or qualified appliance service technician to give you peace of mind, and years of safe use of your new cooktop.
2answers
Bought LG DLE2532W Dryer it in Canada, need to use it in Europe
For to use it with a 220/ 240vac system,you will need to convert 110vac 60hz/to240vac 50 hertz single phase therfore your transformer should have this rating,also it has to be able to handle up to 3kw or 3000watts in power, maybe just as cheap buying a new drier....
1helpful
DC FEEDBACK FAULT ON CHLORIDE EDP70 30KVA UPS
Sir,
I have edp70 30kva 3:3 out problom is that ups is just given me the 20 to 30 sec backup. and output 2 phase 220v last phase is given just 15v ac. plz send me the tecnicaly solution.And plz reply as soon as my email, [email protected]
Power supply
What is your price range ?
Top Exide Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you an Exide Computer and Internet Expert? Answer questions, earn points and help others
