SOURCE: camera beeps 3 times the shuts off
OMG! so i read all these suggestions and nothing worked or i was just confused..tried the tapping thing but didnt work..so i finally just kept twisting the lens and pushing it in and out..it doesnt really move but i was angry and hoping this was doing something..i turn my camera back on a IT WORKIN AGAIN:) im so happy becuz i was so pissed that i had to buy another camera but i suggest trying this method if the table tapping dont work..OH and my lens didnt look crooked at all so if urs look straight and stilling doing stupid beep thing ,,,try this!
SOURCE: The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
SOURCE: On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
SOURCE: system keeps beeping that sensor 3 is low battery
Did you try a system reset? You should be able to bypass.
SOURCE: My unit started beeping continually, I changed batteries, but
I contacted customer support... they tell me the FAQ information on
their own website is incorrect. The opposite is true, therefore the
following is correct:
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Testimonial: "It worked! Once I removed the batteries & unplugged the powerstrip and put it back together, it works like new. Thank You!"
Hi Connie Hehr, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
