Televison & Video Logo
G
Greg Posted on May 24, 2019
I recently purchased Samsung BN94-11709A main board for TV that I can't remove because it doesn't have screws just some metal clips that I don't know how to release. Can someone please help?
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Apr 11, 2006
SOURCE: How to discharge the TV tube?
First off there is no capacitor that holds the High voltage on the tube. Its the tube itself that stores the charge and if you dont discharge a tube properly it will bite you!!You can disconnect the 2nd anode of the tube(thats what the cup is called)that puppy can hold a charge for months as I've picked up used tubes that other service men may have striped out of a junk sets and still got zapped weeks later and it can burn a hole right in you if it bites you the right way. That metal strap is the ground for the crt(the picture tube) The proper way to saftly discharge a crt would be to take a screwdriver perferably a flat tip and connect a cliplead to the screw driver and clip the other end to the ground strap. Carefully slide the screwdriver up UNDER the cup on the crt till you reach the middle of the tube as you will feel it as it wont go any farther. In the meantime you might hear a pop sound and that would be the dischargeing of the tube.. Keep that screwdriver in place a min. of 30 to 40 secs. then remove . Then pinch the cup the oppisite direction on both sides that the wire is running as the cup is held in place by a small hooks on both sides Be carefull not to rip off the cup or bend the small hole suround that the cup is attached. And never ever poke a hole in the cup as I've seen peeps do and when you turn back on a set you will have fireworks as the high voltage will arch out all over the place and if your hand or face is close to it it will get you too!! Now take the clip lead and attach to the grounding strap and clip the other end to where you just took off the cup and your all set.Good Luck with your repair
A
Anonymous
  • Posted on Dec 24, 2007
SOURCE: Purchasing an internal circuit board part for a sharp LC 20S1E LCD TV
send me the model and serial number and i will be able to advise you
Lou Margo
Allied Electronics
[email protected]
Anonymous
  • 192 Answers
  • Posted on Nov 28, 2008
SOURCE: Samsung 50 in Plasma volume Problem. Please help!
In the menu, there should be an option for AUTO VOLUME, see what this is set at, change it and see if it works. Also there is another option for INTERNAL MUTE, though I still haven't found out what it's for, myself. Give both a go. If neither of these work, try looking at the support pages on the Samsung website. Other than that, I can only suggest you take it back to where you purchased it, and ask for an exchange.
marionbagget
  • 718 Answers
  • Posted on Mar 30, 2009
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Anonymous
  • 3600 Answers
  • Posted on Jul 27, 2009
SOURCE: 2004 Kia amanti door panel removal.
did you remove the screws from the arm rest screws? from the top and from the side and they have plugs in them so that you don't see them
How to replace the main board on a Samsung tv
Get inside the set, locate the board. Often attached with a few simple nutdriver screws. Carefully remove the ribbons attached to it and remove board. Installation is reverse of removal.
Samsung ln46a650 - reseating lvds cable
Many tv repair tried to replace t-con to fix.it's well known by now that those lcd panels in those models fail in the way you are describing.You need new panel.I have changed panel in that model before with a Toshiba 46" lcd panel and it's t-con.Your models panel is mounted upside down (t-con at bottom) Toshiba is at top like most.I don't recommend you try this.must know what you are doing. Good luck
TV has recently began displaying 2 images slightly offset from each other with lines. I absolutely love this tv plz help!
you have a digital problem..ive narrowed it down to 2 boards..the Main Bd..and the Tcon board..here are the purchasing details
http://www.shopjimmy.com/samsung-bn95-00496b-t-con-board.htm
http://www.shopjimmy.com/samsung-bn94-05038b-main-board-for-un40d6000sfxza.htm
looks like the main board is on backorder..id replace that first..its most suspect..lemme know how it goes
I have a 3 year old 46" Vizio TV vw46l fhdtv10a that started having some shading in spots for minutes at a time. After some research I came to the conclusion that changing the T-con board was my best...
Its under the metal frame at the top of the set, follow the LVDS cable, the thick one coming out of the main board to the Tcon board...you will need to remove a couple screws to get the cage off that is over the board
2answers
No picture sound only
If the backlight works (meaning that when the tv is on, and the lights in your house are turned off, there is a black glow coming from the screen) then you know your backlight is powered and such.
So far, so good... the next problem lies in one of two places (most likely). It could be the main board which is where your connections plug into the set... If this main boards output to the t-con board is dead, then replacing the main board will fix this problem....
However the more likely problem is with the T-CON board. If you open your unit, there is a silver metal casing with some screws near the top of the screen. You will notice some metallic tape at the top of this metal piece. Also, you will notice a wire harness/ribbon cable connecting just under the base of this metal. Beneath the metal is the T-CON... This board is pretty much the only thing between your main board and the screen.
Replacing the t-con could fix your issue.
If you locate this board, there should be a model number located on the upper-right corner. Be sure and replace it with the correct part.
Please keep in mind that although I am tech savvy, I am not a certified samsung technician.
I hear that a good place to order such parts is shopjimmy.com
Good Luck!
2helpful
Accidently knocked projector and it has got lines accross the picture about every inch or so when viewed on 6 foot screen lines go vertical top to bottom
first reset the settings to factory default. if the lines are still there, you'll have to reset the dmd chip board with the main board. this is a little indepth. if you are not comfortable taking things apart (almost completely) and successfully putting them back together, send it in for repair to an infocus repair center. if you can do it, here you go:
remove the 4 brass and 4 silver screws from the bottom and the 2 silver screws from the back. through the top vent on the back panel and using a flat head screwdriver, unclip the 3 clips holding the back panel on. once removed, unplug the 2 wire harnesses. remove the top and front panel. now unplug the large wire harness and remove all the brass screws on the 2 power supply boards (also the screw for the ground wire). there is a black clip in the middle of the larger power board. remove the boards. now remove the brass screws holding the metal plate on. unplug all of the plugs from the main board. remove the screws from the board. now, facing the rear of the machine, the main board is attached to the dmd chip board behind the lens assembly under the heat sink. do not lift the board up from the back, pull it back towards the rear of the projector away from the dmd board. now reinsert it all the way and replace everything you removed in reverse order. good luck!
1helpful
2answers
My samsung lcd tv wont turn on. It just clicks then the light flashes beside the power button
I am having the same issue with my 52" Samsung ... it just started recently and it appears to be cycling the inputs after it powers on ... is that what yours is doing too? Please let me know if you find anything out and I will do the same ... sneye_per at the yahoo 8)
26helpful
2answers
How to take apart the samsung gravity sgh-t459
Remove battery cover and battery. Using a #00 philips head screwdriver, remove the 6 screws around the perimeter. Slide phone open and carefully pry up on the edge of the green (or blue) trim near the space bar. The colored back should unsnap. There will be two philips head screws visible on the now exposed circuit board. Remove these and carefully pull up on the rectangular ribbon cable to disconnect the main circuit board from the keypad circuit. Carefully peel the two button contacts from either side of the phone. On the spacebar edge, there will be a clip holding the circuit board in place. Gently pry it away from the board and the board should come free (there will be clips on the other side but you should be able to lift the free side of the board up and slide it out from under the clips). Remove the QWERTY keypad. Unglue the remaining ribbon cable from the keypad frame. Undo the 8 silver screws securing the keypad frame to the hinge and lift frame off. There will be 4 screws visible on the back of the LCD case. Remove these and insert a thin plastic spudger at the top of the frame and carefully work your way around. The two halves will separate (should hear two snaps on each side). You will now be into the keypad/LCD section of the phone. Removing everything else is pretty straight forward. Follow these directions backwards to reassemble.
I have the same problem with my tv.
take back off lie flat
where the hd leads go into that board remove the screws at the top and bottom as its one long unit top to bottom
unscrew metal shield as well
remove all cables from board 2 ribbons are locked and require clipping down then ribbon removes
flip board over remove metal can to expose board notice 2 TSOP chips at top look att the pins one should look dull and not shiny
to fix i used heatgun a quick blast on pins sorted problem out
mask off board and chip around with metal etc... to not damage board.
34helpful
13answers
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
