SOURCE: Bissell Lift Off pet revolution vacuum losing suction
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it.
SOURCE: Bissell Quicksteamer Powerbrush, modele 2080
There is a gasket on the cap, part #2035541 , gasket will come with the new cap.
SOURCE: my bissell proheat 2x wont vacuum up water
There is a float (usually looks like a red ball) that rises up if water is in danger of getting to the motor. Sometimes they stick.. Give it a poke to free it up.
All the best,
WD
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you
need and a manual you can view:
Bissell 7901 Belt and Manual
Testimonial: "just what I was looking for thank you"
SOURCE: My Bissell liftoff Revolution won't turn on. Is
Vacuums are not usually fused, but may have a circuit breaker--look for a small protruding button that when pressed, resets the breaker. The plug on the end of the cord may have a wire broken within the plug--replace it with one from a hardware or home center. Another common problem is the power switch may have failed. Order a new one from an appliance parts house. Good luck!
