SOURCE: No print catridge error showing on display
plz remove the catridge and reinstall the catridge properly then uninstall the printer driver and restart the system then after restarting the system then reinstall the printer driver and restart the system again then after restarting the system check
SOURCE: RICHO AFICIO 650 SHOW ERROR 890
The code 890 do not exist like 880 but, if it is 980? the problem can be in the hard disc...
Incorrect parameter sent to the HDD controller.
First try
reset the software… press the point and numeral
key simultaneously until automatically it is off the copier, several seconds can
pass, the copier back on automatically. The software will
have been loaded again.
If the problem persists it proves with another
hard disk,
since the
other possible solutions already are more complicated; these are:
· Software defective
· SBICU defective
Another
problem that sometimes cause erratic errors in these copiers is that it has
fallen develop in some sensor having caused short circuits that annul to some
times some voltage of the power supply interrupting processes indispensable for
software. Example “by developer in the ID sensor” the copier scanned but nothing more. Developer in the sensors of the feeding units produced a code 322 can
seem incredible but it is thus.
For it
would recommend a deep cleaning of the sectors of the image unit and everything
what is under the development unit.
SOURCE: my aficio richo 2016 black
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
