Televison & Video Logo
RO HE Posted on May 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a soniq tv model n75ux17a-au and I am unable to set it up
Franco Dosil
Level 3:
Top Expert:
  • Televison & ... Master 10,542 Answers
  • Posted on May 24, 2019
Franco Dosil
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
378629
Points
178965
Hello RO, I sent you the link to download the user manual, so you can follow the steps for the configuration of your TV Soniq
I hope you can configure it
Greetings Franco Dosil
Hola RO, te envio el link para que descargues el manual de usuario, para que puedas seguir los pasos para la configuracion de tu TV Soniq
Espero puedas configurarlo
Saludos Franco Dosil
https://data2.manualslib.com/pdf6/128/12758/1275799-soniq/n75ux17aau.pdf?a558202ff9ec1e3cbdc5379217878b33&take=binary
5 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on Jun 08, 2014
SOURCE: When I turn on the tv I am only getting the the
Do a hard reset to this TV and check. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
gopakumarg43
  • 76851 Answers
  • Posted on Jul 22, 2014
SOURCE: I cannot retune my soniq 32" hd LCD tv model
Its main system control memory IC might have damaged. Replace it and check. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
gopakumarg43
  • 76851 Answers
  • Posted on Dec 16, 2014
SOURCE: Upgrade came for soniq E55V13A-AU now I have lost signal. Can you offer a solution
After the upgrade, the TV might have reset itself to its factory settings. You should re-tune and re-adjust all its settings as before. Refer its user manual for details. Gopakumar Gopalan Google
gopakumarg43
  • 76851 Answers
  • Posted on Dec 18, 2014
SOURCE: 40 inche soniq tv model number e40w13a-au sn/lf4qa3616684 cant rember password how can i fix this as i cant change a channel now
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
gopakumarg43
  • 76851 Answers
  • Posted on Nov 10, 2015
SOURCE: My SONIQ FLATSCREEN MODEL E32W13D-AU HAS STOPPED WORKING BUT STANDBY LIGHT IS ON??
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2helpful
2answers
Hi there I'm trying to update my Soniq tv because it's that far out of date it won't let me check for updates
Eventually the updates stop as the hardware becomes dated to any new software version. The idea is that you update the television.
https://www.google.com/search?q=s65vx15a-au+software+download
I have a soniq TV trying to use a sansai universal remote but won't work can you help please
How do i enter my wi-fi password into my soniq tv e55s14a-au with the remote control
Hello Graham,
Here are 2 links to your tv manual. Click on the Soniq link, it will give you the opportunity to enter the model number of your set. Just write it in there Without the "au" .
On the results you will see 2 manuals. Click "View Manual" on both (separately) and you will be able to do it. The manualslib link is complementary. Good luck, JP
https://www.manualslib.com/manual/1104333/Soniq-E42s14a.html#manual
https://soniq.com/au/support/product-manual
2answers
How do you reset a Soniq S43V15A-AU smart tv to factory default?
If it’s not found at the end in the settings menu of the tv, unplug the tv for one minute and plug it back in. Some TVs go back to initial default after this.
3answers
How do I get update for firmware of Soniq TV E32V15B-AU
What makes you think you need to update the firmware, that isn't a common thing to have to do?
2answers
I have a Soniq E55Z11a TV and we did an auto search for channels. It is stuck on Installation Guide screen as no remote.
Does switching it off and back on at the wall help?
Page 13 of the manual shows the button functions (I'm sure you know). The alternative is to buy a dedicated remote from some seller like ebay.
SONIQ E55Z11A AU Instruction Manual Page 13
REPLACEMENT SONIQ REMOTE CONTROL QT141 E46Z10A E46Z11A E55Z11A E55Z11A AU...
Why does it display "no signal" when requesting to watch tv ?
If I know the Sonic TV model, there is NO TV tuner built-in.
What sources have you connected to which port ?
Typical sources are
(a) Cable using Set top Box using HDMI
also see
Soniq tv problems
1helpful
I am looking to purchase a spare parts for A Soniq model NO E32W13D-AU 32' HD LED LCD TV COMBO
Here is a good site for Soniq spares if yo know the part number:
http://soniq.com/au/spareparts/
Also eBay can be a good source for parts such as PCBs and they can be much cheaper than from the manufacturer.
Code for soniq tv
The codes are dependent on the remote so you'd have to also list the remote name and model, however, this is what Soniq wrote to another user with the same problem: Hi, we do not have the remote code for universal remote control. We recommend our customers to use a genuine SONIQ remote because some universal remotes are not compatible with SONIQ TVs and they may not have all the special buttons required. Please call our spare parts team on 1300 765 663 and they will be able to assist you further. Thanks.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
