l
lolade Posted on May 24, 2019
My richo aficio SP3400SF does not recognize toner after refilling it. it displayed life end print catridge and indep. supplier print catridge
Al Alent
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on May 25, 2019
 Al Alent
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
5242
Points
53
Try using the Ricoh factory toner cartridge. In my 20 years as a printer tech, I've found the the factory parts are recommended for a good reason: they work.
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Dec 20, 2007
SOURCE: brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Anonymous
  • 417 Answers
  • Posted on Jan 08, 2008
SOURCE: Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Anonymous
  • 78 Answers
  • Posted on Jan 21, 2008
SOURCE: toner low, tone life end
There is a gear on the left hand side of the toner to reset the toner count this can cheated be rewinding it. Yes the design is to stop the refillers or at least slow them down a bit. If this fails purchase a new genuine toner but I have seen problems with the switch that resets the toner (Either the spring on the switch has popped off or the main board has failed).
Anonymous
  • 5 Answers
  • Posted on Jul 13, 2009
SOURCE: Toner cartridge is full - "toner life end"
when the printer is in "ready" state, press the GO and SET at exact the same time.
Now, using the (-) < button you can choose any "service" option to fine tune te printer
TONERLIFEEND is the first in the list, press the "set" button en chose "Nothing" and press "Set" again
Anonymous
  • Posted on May 03, 2010
SOURCE: samsung scx-4200 refilling second time
CAN I RESET MY SAMSUNG SCX4200 TONER CHIP MANUALLY BY SOLDERING
How to fix error "end of life"
You didn't say what printer manufacturer or model number
If you have simply refilled the cartridge, you'll need to replace the smart chip on he cartridge as well, or reset a sensor actuator, depending on model. If you bought a refilled or compatible cartridge, take it back for a replacement.
2answers
3helpful
Risoh aficio sp 3510 sf
my printer richo sf 3510 sir. my problem replace required soon print cartridge show on the display
RICOH AFICIO GX3000 SF. PURCHASED OCT 2009. SERIAL R3178000026. RAN OUT OF MAGENTA COLOUR. REPLACED WITH REFILL. WORKED FOR ONE DAY THEN MESSAGE SAID REPLACE MAGENTA CARTRIDGE AGAIN. ASSUMED CARTRIDGE...
There is a computer chip in the cartridges that monitors the ink level. If you are going to refill the cartridge instead of purchasing a new one, the only way to make that work is to stop using it before it gets low enough to trigger the comuter chip. When the ink level goes low enough to report it is running out, there is no turning back for that cartridge. If you refill before that point, they usually continue operating as normal.
There are numerous problems with using the refill method instead of purchasing a new cartridge. Once the seal is broken to add ink, they can leak into the printer and cause damage. Companies that sell refilled cartridges can replace the ink level sensor and by pass the problem to guaranty their product will work in your printer. Using refilled cartridges voids your warranty, so I will not suggest using them.
Now lets work on the problem with your printer and get it running again.
I have a couple of questions for you.
You mentioned you used a refilled cartridge and it worked for a day before it stopped. You also said you contacted a supplier who sent a replacement.
Please clarify the following for me:
Did you refill a cartridge yourself and it worked for a day before stopping, and then you bought another cartridge from a supplier and it still does not work? If this is the case, tell me what happens when you try to print? Does the unit not respond? Is there an error on the display? Does the printer say its out of ink when you try and print? Are there flashing lights indicating a problem? When you removed the old cartridge and inserted the fitted replacement, did the printer recognize that a catridge had been removed and then recognize that a new cartridge was installed?
Troubleshooting instructions depend on your answers to the above. Please send me your answers using the comment or reply link next to your question posted on Fixya. Or email me at [email protected].
Did you buy a refilled cartridge from a company who sells them and it worked for a day before stopping so you contacted the supplier who gave you another refilled cartridge which still does not work?
If so, please tell me what happens when you try and print? Is the unit responding? Remove the cartridge from the printer. Turn the printer off, leaving the cartridge out. Wait a minute or so and turn it back on. Does the printer say that the cartridge is missing or not installed? Put the cartridge back in the unit, and tell me if it recognizes that a cartridge has been installed? Does the printer say the cartridge is still out of ink? Is there an error code on the display? If so, what is it?
If there are no errors displayed and the problem is that the printer just does not do anything when you try and print with the cartridge installed - then check for pending documents in your print que that might need to be deleted. Pending documents will cause it not to print until cleared.
To check your print que, click on the arrow next to the clock on the bottom right side of your pc screen. See if there is a picture of a printer and if so, right click with your mouse on top of that Icon and open the print que. If you see documents pending, click on each one and choose delete or cancel until there are none left. Once the que is empty, try printing a test page and see if this solves your issue.
Please send your answers to clarify the problem as soon as possible and I will help you troubleshoot and repair this printer. Thank you for using Fixya!
2helpful
2answers
Toner Life has ended
Did you pull the plastic tape on the cartridge?
13helpful
2answers
Samsung scx-4200 refilling second time
Toners
Sorry for long delay. Yes you should be able to buy toner to refill your empty carts. i always recommend using original stuff though. Saves any complications and possibility of wrong toner type getting used.
1helpful
Toner low, tone life end
Top toner Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Ron Jeremy
Are you a toner Office Equipment and Supply Expert? Answer questions, earn points and help others
