hi, i installed handy cafe server but when i click to be open it does't work. no error just don't open, i try to re-start my pc-server but still does'nt open. please help.
its very easy to display ads and banners in internet cafe.You can make extra revenue from it. Here is the tips to add banners in handy cafe server and it will show when a user log in to the client computers.
<br />
<b>Login</b> to <b>handy cafe server</b> using <b>user name and password</b>
<br />
<br />
<br />
Click on <b>Options</b> Tab
<br />
<br />
<img src="shabype.JPG" /><br />
<br />
<br />
<br />
Select <b>Banners</b> from the list and Click on <b>New</b>
<br />
<br />
<br />
<img src="shabype_0.JPG" /><br />
<br />
<br />
<br />
<b>Add/Edit Banner</b> will pop up.Click on <b>Add button</b>
<br />
<br />
<br />
<img src="shabype_1.JPG" /><br />
<br />
<br />
<br />
<b>Browse</b> for the banner file ( must be a video file)
<br />
<br />
<br />
<img src="shabype_2.JPG" /><br />
<br />
<br />
<br />
Click on <b>Open</b>
<br />
<br />
<br />
<img src="shabype_3.JPG" /><br />
<br />
<br />
You can see the attachments. Click on <b>OK</b> and then Click on <b>OK</b> again.
<br />
Now you can login to any client system and see the ad displaying .You can set <b>time period </b>as your wish.
There are many ways to do this. first, you can install a web proxy. second, you can block urls from your router. third, you can create your own dns.
I can help you with whatever your needs are. However, I suggest you create a transparent proxy. That way you have a much better control over the traffic at your internet cafe. and a firewall of course.
I am sick of my handycafe server keeps changing its ip addres.....i have to reconfigure from each client every day.....how can i just change my handy cafe server ip address......?
how to unlock the cafe manila client software when IP address is encoded wrong, it appears LOCK without password. I tried to use CTRL+ALT+DEL but still no use. Do i have to reformat?pls help **** just press esc and choose admin.. the default paswword is pass hope this helps..
Check if the LAN cables are connected properly, make sure that client PC's have handycafe client installed and connected to the hub/switch with the server PC.
In some cases wherein the server has two LAN Cards installed, make sure to choose the LAN Card which is connected to the hub/switch where the client PC's are also connected during the initial start-up of the Handycafe software.
Note: Check if the hub/switch or router (whichever you're using) does not have a problem.
