SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
SOURCE: can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
SOURCE: Will cleaning my Troy-Bilt TB25CS carburetor heal it?
Since the air from the air filter does not go through the carb, the carb cleaner will not either. If you remove the carb and spry all of it that you can get to, you may get the plug. If you were to open the carb and go through it and clean it you would need to get new gaskets and maybe that will do the job. You may be able to adjust the carb. There is a "hi" and "low" setting. Try adjusting the "hi"...Lee
Testimonial: "Thank you for getting me started! Hope I can get a little more info on the process! "
SOURCE: can't get the head off troy-bilt weedeater to replace the line.
Threads are left hand. Hold the black wheel and use large plier or pipe wrench to turn the knob cloclwise
