SOURCE: E.E.C fuse keeps blowing in 1991 Ford Explorer
if you replaced fuel pump i would look at backward wiring when replaced and i would start at the source of work if your vehicle was working fine before replacement then 9 out of 10 it will be your fuel pump wireing
sometimes when putting wireing back together the connectors have the missing clip and in turn you can turn the wireing in both directions now where positive is touching the ground on both sides of connector kris kross problem check your work this is crucial use a test light to find the right wires where they go
SOURCE: horn fuse keeps blowing out
Check the wiring around the horn and make sure nothing is touching metal...look under the hood at the horn and make sure everything is pluged in and there is no water on any plugs or wiring...Make sure the fuse is the correct number (ex: 10, 20, 25) If it is still blowing out the fuse then you after you do some checking then it is a short in some wires
SOURCE: fuse for instrument & tail lights keep blowing
if its blowing fuses, you have a short(power being touched to ground) Electrical can be hard to trace. Find you a wiring schematic for you vehical and trace each wire, look for loose connections and possible wires melted to each other. Hope this is a help.
SOURCE: 2001 Ford Windstar speedometer fuse keeps blowing
We had the same problem but when we put in a new fuse it smoked. It turned out to be something with the master cylinder and required the changing of a 20 dollar part by the mechanic and problem solved
SOURCE: HOBART FX-20 dishwasher out of order
There is one glued to the lower panel on the inside. Hobart is very tight lip'd when it comes to getting any info from their web site. Best I can do, sorry.
Press Ok, Accept or
replay
I have a solution for
this
Bruce
