My TV does not respond to the remote. I can only turn the tv on and regulate the sound by pushing the bottons on the TV
IS
it a universal remote? If yes, remove the battery, wait for 10 seconds or more,
fix the battery back in and re-register the remote with the TV by
entering the code. But it the remote works with the TV without code, try
again. If this doesn't fix the problem, please read further.
Try
the remote with new batteries, ff new batteries did not fix the
problem, then it means the problem is either from the remote or the TV.
Remote:
Check the remote battery terminal, see if its not rust. Also,
disassemble the remote, can check the connection between the terminal
and the remote board, see if there is no disconnection of any kind.
If
after checking and all seems well, then it means the remote is
defective. To confirm, borrow a remote, test it with the TV. If it
works, then it means you need to replace your remote. But if the remote
you borrowed does not work, then it means the problem is from the TV and
not the remote.
TV: There is a sensor in the TV that
communicates with the remote. If this sensor is defective, the remote
won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So
do the above troubleshooting and let me know if the problem is from the
TV or remote. If problem is from the remote, you need to do a
replacement. But if otherwise, let me knows as well.
I hope the above makes sense to you.....
Good luck.
