Water does not come into the softener section on the last rinse or the overflow holes are clogged or electric valve for rinse is faulty. My experience is that in over 95% of cases mechanical failure because some residues or deposited calcium carbonate at the water inlet holes (water inlet holes clogged above softener compartment).
Practical advice:
- If required, pour fabric softener into the compartment marked
(the amount used must not exceed the "MAX" mark in the
drawer). Otherwise, softener could be takes in washing or prewashing phase what can cause stains on laundry depending on temperature. (Especially in washing phase at 60-90 Celsius)
- If you use thick softeners it is recommended to dilute with water.
- After washing cycle finish, residues of detergent, softener and water may remain in the dispenser. It is recommended to clean
the dispenser regularly to remove any residue.
Dado
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
SOURCE: AEG Lavamat 72640 Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
SOURCE: Remove the fabric softener compartment for cleaning
i cleaned it then when i use fabric softener i also add a lot of water
i have a bottle of water sitting on my dryer for this
SOURCE: Washing machine does not take fabric softner
Obstruction, please take the whole soap compartment out and do better job with old tooth brush on the compartment in the sink and the machine itself. Should do it unless you live in very cold environment.
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
