Hello Jeff, I was looking for the user manual of your CB Radio Hatadi, to know what fuse it takes and there is no information
I would try the 5 Amp, I would place it and it would work for a long time to the BC Radio, checking that the fuse resists the transmission work
If it does not resist, I would put the 10 Amp and would do the same test
If it does not resist either, then you already have problems with the equipment
If so, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Jeff, estuve buscando el manual de usuario de tu CB Radio Hatadi, para saber que fusible lleva y no hay informacion
Yo probar?a con el de 5 Amp, lo colocar?a y har?a funcionar por un rato largo al BC Radio, comprobando que el fusible resista el trabajo de trasmisi?n
Si no resiste, pondr?a el de 10 Amp y har?a la misma prueba
Si tampoco resiste, entonces ya tienes problemas en el equipo
Si es as? busca un servicio t?cnico especializado
Espero Puedas resolver el problema
Saludos Franco Dosil
SOURCE: found 5amp fuse should be 10amp for the ecm would
No not as long as it wasn't popped. Do install the correct fuse of course.
Battery keeps dying and radio defaultig to am
