SOURCE: jensen vm9022
was the unit new or was it a demo? if it was new in a box I would take it back to where you purchased it from and exchange it. some decks the code can be reset such as the case you bought a used car ect., and others you need to replace the code IC in either case you will need to contact jensen custmer service or get the technical schmatic.
good luck stereo tech
SOURCE: sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
SOURCE: jensen vm9022 Disable touch screen???
try reentering the code. if not the screen whent out. i bought one of thees screens. and had to return it more than 4 times the screen whent out . cd player didnt work .ect.....ect...
SOURCE: Jensen car stereo VM9022 has a password Need to bypass it
call Jensen at 1800-323-4815 they will give you the code
SOURCE: need to reset my password
the reset password for your player is 012345 or 543210.
To reset the player, check the manual for the procedures but if you don't have the manual, check the below link: When the page opens, click owner manual at the left part of the page and you will see Reset. Click on the reset and you will go straight to the reset aspect of the manual.
Note that the manual might take some time to load completely, so you need to be patient for it to load fully.
http://a248.e.akamai.net/pix.crutchfield.com/manuals/110/110vm9022.pdf
Good luck.
