Garden Logo
B
Bruce Jackson Posted on May 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toro 20067, just replaced the traction cable and now when pulling the mower backwards I feel some drag or binding. The cable appears to flex.
Ron Stone
Level 2:
Sergeant:
  • Expert 408 Answers
  • Posted on Aug 15, 2019
Ron Stone
Expert
Level 2:
Sergeant:
Answers
408
Questions
0
Helped
112275
Points
562
Incorrectly adjusted
5 Related Answers
Anonymous
  • Posted on May 06, 2009
SOURCE: the cable traction cable is broken on my toro
I changed the cable on my toro mower but i cant make it go unless i pull back on the handle .i cant find a picture to see what i am doing wrongcan you help. Thanks
Anonymous
  • Posted on Aug 09, 2009
SOURCE: need to replace pull string on lawn mower
how do i change the pulling string on my toro 22 recycler
Anonymous
  • 20 Answers
  • Posted on Aug 29, 2009
SOURCE: Self propel toro mower will not
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
mickey813
mickey813
  • 472 Answers
  • Posted on Oct 16, 2009
SOURCE: Toro 20038 Lawn Mower rear drive wheel(s) lock
sounds like thw cabel may be jaming up not releasing if you fold the handels dowen that may whats wrong
Anonymous
  • Posted on Mar 12, 2012
SOURCE: Replace the cable traction (part #105-1844)
I just replaced mine and it was a little difficult and took me roughly an hour to do. First, download the walk behind power mover drive systems at https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
While they do not specifically address replacing the cable, you can find out how they do it when replacing the drive belt. As I said, it took me about an hour and I just about had to remove the transmission and rear drive assembly in order to unhook the original cable. Good luck!
2answers
How is the traction cable adjusted on Toro Model 20027, Serial # 20005663. I'm replacing the cable and the new one is slightly different from the old one, but the Toro shop tells me it's the proper...
There is a large black plastic nut at the end where the cable attaches to the mower transmission. Turning it clockwise tightens the cable (engaging traction bar is tighter) and counter-clockwise is loosening the drive. If the cable is a little too long, you have to tighten it more.
I have ordered and received a new traction cable for my Toro Recycler Lawn Mower. However, no instructions. How do I attach this cable so that the mower is once again self propelled?
That can be a tough one the cable that houses the throat cable is the secret to make it work. Look at your old cable and make sure it is in stalled in the same position and work backwards until it works . If the cable is not adjusted right you can not get full power.
Apr 21, 2014 • Garden
How to replace a Broken choke cable on zero turn toro
at the carburetor there should be a 5?16 bolt that hold that end on. under the panel there should be a 9?16 or 1?2 nut that holds that end on. take the bolt out and unhook the end at the carburetor and the nut under the panel. replace in opposite order. just don't get the cable in a bind or it may be hard to pull.
2helpful
2answers
Toro rear drive personal pace, hard to pull backwards
Check drive cable for proper routing and kinking. Replace cable if bad. Check end of cable where connected to drive assembly ensure area is cleaned out of obstructions. If cable has stretched over time replacement is required.
Jun 30, 2012 • Toro Garden
How do you change the transmission in a 20067 toro personal pace lawn mower
I followed this video and it was pretty accurate. http://www.youtube.com/watch?v=eSaNVZaUi-k This is for a newer model mower but most steps are the same.
10helpful
2answers
The cable traction cable is broken on my toro personal pase lawn mower. part number 105-1844 how do i change it
11helpful
Cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
2helpful
Replacing traction cable
Go to toro.com then customer care then manuals and parts type in model then find owners manual to download.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
