Question about Crock Pots & Slow Cookers
Keep warm light and cooking light do not come on
I have a prolectrix slow cooker and the only two settings on it I want to cook a lobby do I leave it on warm or cook I'm confused
The Cook setting is High heat for cooking the Warm setting is Low heat just to keep it warm after cooking is done, really hope this helps?
Feb 21, 2015 | Crock Pots & Slow Cookers
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
I need the user instructions for use
Hi and welcome to FixYa, I am Kelly
I see I am nearly a month late in replying to your post. I just answered another post and when I finished I saw your question.
This is driectly from the user's manual that you can find here with some difficulty:
(Avoid answering questions by looking for the blue text that says "security code" and clicking that) Then enter the 4 digit code to download the manual that is 209k)
2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
Kelly
Feb 05, 2011 | Rival 38601 Smart Pot 6-Quart
Which will provide the lowest heat? low 10 hours or warm setting. Thanks
The WARM setting is the lowest heat. Here's a quote from the user manual:
"WARM is ONLY for keeping already cooked food at the perfect serving temperature. DO NOT cook on the WARM setting."
This is because at the WARM setting, the temperature doesn't get hot enough to kill food-borne bacteria.
Jan 18, 2011 | Rival 38601 Smart Pot 6-Quart
On a Rival crock-pot, which is the higher cooking temperature: Low or Warm
Low and High are cooking levels, warm is to keep the food warm after it is cooked.
Mar 15, 2010 | Crock Pots & Slow Cookers
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
May 19, 2009 | CorningWare SC60 Slow Cooker
Warm setting
Units such as the "Countdown" and "Recipe" Smart Pot™ slow cookers have a designated warm setting. Basic Smart Pot™ slow cookers have an automatic warm feature that activates a keep warm function when the cooking time expires. This type of warm feature will not activate without the set cooking time expiring first.
Feb 10, 2008 | Rival 38601 Smart Pot 6-Quart
Can't go straight to warm setting
Hi, Guys,
I discovered this solution by accident. To get my crock pot to go to the "Warm" setting directly, I begin by pressing and holding the "Cook Time" button. Then, with the cook time button held down, press and release the "Off" button, holding it down for a second or so and then releasing it. Finally, lift your finger off the "Cook Time" button. Presto! The unit will be set on "Warm." So the key to this is to press and release the "Off" button WHILE the "Cook Time" button is being held down. Might take a couple tries before you get it, but then you'll see that it works every time.
Jan 27, 2008 | Rival 38501 Smart Pot 5-Quart
Crock Pots & Slow Cookers Logo
22 people viewed this question
Top Crock Pots & Slow Cookers Experts
ellenskitche
Irene Tulloch
Marvin
Marvin
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
