Question about Bosch Washing Machines
I have a Bosch SHU9902UC/U06 Dishwasher that won't start.
I depress the start button, choose the cycle and nothing happens. I have power - if I open the door, the chosen cycle light comes on. Suggestions?
SOURCE:
dragonsthatk
  • 547 Answers
SOURCE: SHU4302UC/U06 runs for hours. What's the fix?
timer
Posted on Feb 18, 2009
DrakeTech
  • 61 Answers
SOURCE: I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Posted on Dec 30, 2009
  • 128 Answers
SOURCE: My dishwasher simply won't start
Start with the simple things and work your way from there. You will be amazed how many people call a plumber who flips a breaker or simply clears a stuck float valve (for $80 minimal fee).
If no lights are coming on.
First check the breaker to the machine.
If you have an exposed power source to the machine such as a plug or junction box open the box and check the wiring is intact and not rusted etc. Take care here and shut the breaker off first.
No go so far?
Check if your float valve is jammed.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
Not the float valve either?
Check the door interlock latch.
Much like a washing machine a dishwasher will only operate with the door closed (or when it thinks it is closed!). There is a metal tab that engages a switch in the door. This is the same switch that activates as you operate the handle to open the door. If it is misaligned it will not signal the machine that the door is closed and the machine will not operate.
You can check this by overriding the locking tab. Put a screwdriver in the door latch and press the switch. You should see the lights come on and power flow to the machine.
Note: if the machine is in run mode you will get water spraying.
To fix this problem bend the tab to properly engage the switch. Or if necessary loosen the screws retaining the switch and move it to correctly align with the tab.
Not it?
OK now you are into electronics.
First is quite simple. Some units have an internal fuse to protect the control panel. Check that first. Take your time and take care. Turn the breaker off.
The control panel is screwed in place. Remove the screws and gently remove the control panel. Take care not to have parts of the door latch fall out or springs drop out etc. On newer units it is very simple as it is just a circuit board. Look for the fuse and check that it is OK. Replace if necessary with correctly rated thermal fuse.
Do you have water in the bottom of the machine?
Power is there, lights are one, seems to want to work. Water will come in but will not drain.
A small amount around the drain is normal for some machines. This is held to keep the pump primed in some units. However it should not fill the bottom of the unit. You know what it normally looked like so it if is full then you probably have a jammed float valve as above or a clog in the drain.
Drain clog.
Remove the cover from the drain in the bottom of the dishwasher. They usually lift out or have a few screws holding them down. Simple to figure out just take your time and try not to force anything. Look for a clog and clear if necessary.
Your drain can run either direct to the drain under the sink or to the disposal unit if you have one. The drain can clog at either point.
Check by disconnecting the drain line from the dishwasher where if connects to the sink or disposal unit. Look for a clog and clear if necessary.
Water exits the machine via the drain pump. If it is not operating the machine will not drain. It will fill usually to the point where the float valve lifts and does its job by stopping the machine before if floods your house.
If you have water in the machine to the point the float valve is lifted then drain it out first.
Your machine should be running now. Lights will come on and it will run again to the point where if fills with water and trips the float valve again. If so then check the pump and timer (see also timer below).
Remove the units as per below.
If your pump is belt driven check he belt (very few have belts).
If direct drive switch the unit on and let if run to the drain cycle. If the pump does not come on check for voltage at the pump during the drain cycle. If you have voltage replace the pump. If not it is the timer that is faulty (see below).
OK now your are getting to some deeper issues. Not necessarily hard but only go here if the simple things are OK.
If you are not getting water into the unit but you have lights on and you hear clicking and the timer runs and things are trying to work then we know you have power and the timer is running.
No water coming to the unit.
Make sure nobody shut the supply line off. There should be a tap under the sink on the water supply line to the unit.
Turn the unit on an listen at the base for a click as the water supply solenoid (electric switch) opens. No click?
Check the solenoid. Remove the machine from under the counter. There will be screws holding it to the underside of the counter. You may have to lower the legs to get it out. They turn with a wrench to lower.
Under the unit where the water supply line comes in is a solenoid switch it opens to allow the water to enter the machine. Water comes in under household pressure (it is not pumped in by the unit). Chances are it is faulty. Replace it as it can't be serviced.
Still no luck?
The unit is guided by a timer. The timer tells the machine what to do and for how long. If it fails the unit will stop or jam in one cycle. If you have a physical switch the you turn to select the type of wash cycle check it. If you are all touch control then replace the whole board or machine.
To check the switch open the control panel above and use a voltage tester to see if you have current at each cycle point. Cleaning sometimes helps if not replace.
Hope this helps you. Please rate this tip for me.
Adrian
Posted on May 03, 2010
SOURCE: Bosch sms 4012 dishwasher
hiya,
Can't solve this problem unfortunately but I however have been given a Bosch sms 4012 without the manual and was wondering if you could tell me how to make it go.
Posted on Oct 21, 2010
rickead1
  • 1998 Answers
SOURCE: Have a Samsung gas dryer, power comes on and panel
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
Posted on Jul 04, 2011
Bosch Dishwasher Model SHU5315UC/U06 Looking for Cycle Buttons That are no longer avail #176079
There are several places on-line where you can find this parts. Depending on where you are. For example you can look up www.dlpartsco.com
May 08, 2016 | Bosch Dishwashers
How do i operate a basic bosch dishwasher
On many Bosch dishwshers (especially those with the controls on top), they expect your to press the appropriate cycle and option(s) buttons, and then press the Start key, ALL WITH THE DOOR OPEN. Immediately after pressing the START button, close the door (within 3 seconds), and the dishwasher should start.
On other Bosch dishwashers, if you open the door, the poser button is automatically turned off. On those models, you must close the door, turn the Power button ON, and THEN press the appropriate cycle & options buttons. If your dishwasher has a START button, then press it; otherwise just wait 10 second with the door closed.
See? There is no such thing as a "basic bosch dishwasher". Next time, if you have a question, please provide the model number of your dishwasher (or other appliance).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 20, 2015 | Bosch Dishwashers
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
The machine will not turn on, all the other buttons work, but I depress the start button and nothing happens, even tried holding it down, no results...
When you turn your machine be sure you choose a program (such as basic bread, usually #1 on most machines) After you do that then push start. Have you chosen your program and it still doesn't work?
Oct 11, 2010 | Breadman TR2500BC Bread Maker
Dryer has power but nothing happens when you press the start button.
First check the door switch to make sure it is clicking when depressed. Open door and depress the door switch with your finger, should hear a click. If you do not replace the door switch. Other problem will be the thermal fuse located on the blower housing. Small white plastic piece with 2 wires going to it. Hope this helps.
Mar 09, 2010 | Whirlpool GEQ9800L Electric Dryer
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Washing Machines Logo
35 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
