When it first started to do it it only blinked a few times then came on as normal. I thought I could live with that but it started to get longer and longer untill it no longer turns on at all except for the Teac logo. Any ideas????
SOURCE: Sony KP57WS510 Blinking 8 times
You have a strt up problem. I found, in a similiar Sony Big Screen a couple of fixes. First thing to try is unplug the set from the wall for about 15 minutes and then plug it back in and retry the set. If this corrects the problem, I suggest you purchase a good ( Not a 5 dollar piece of junk) surge protector. ( One rated at 500-1500 joules. A good surge protector may prevent future processor lock ups. If this doesn't correct the problem, the problem lies in the circuit boards of the set. I found one problem in a Sony like you describe had a bad convergence chip and a burned resistor in the same board. Good Luck
Ed
NC Electronic
Mills, Wyoming
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
SOURCE: Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
SOURCE: sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
