SOURCE: Sharp Copier 2025 error steady CH
I believe that that error code relates to the dorter. Make sure it is seated correctly against the copier.
SOURCE: MY SHARP AR-5320E COPPIER SHOWING CH ERROR CODE
Some part/ unit (developer, drum, imaging unit, fuser) or something else is
not installed properly or is not plugged into the machine. Check all
assemblies that can be removed from the copier, and make sure they are
installed and plugged in properly.
The 'ch' code will automatically
reset when the fault is found.
SOURCE: ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
SOURCE: My sharp photocopier is AR.5316E,and recently is showing "Ch"
Ch means the side door is not closed or the toner is not installed correctly.
SOURCE: error code ch
CH mean any kinds of door is open or not close properly.Please close door properly.right side or front side.it has a connector switch it is open or displace.
