Question about Marantz Audio Players & Recorders
Marantz sr4500 not switching only standby light work
I HAVE A MARANTZ SR880. WHEN I SWITCH IT ON, IT STAYS ON STANDBY MODE. WHEN I SELECT INPUT, IT CLICKS AND THE STANDBY LIGHT FLICKERS. WHAT DO I NEED TO DO?
Possibilities for dry soldering. its a Common problem with this model. Also can happen because of aging . Its tedous procees to open and repair the av receivers. Its better to find expert who can do it for you. i think Marantz authorized service center will not do this as its an out dated model .
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
Feb 18, 2015 | Marantz Audio Players & Recorders
Protect message
If you are using AV cables from your TV for movies and a different hookup for the X-Box would explain that the relay for the sound inside your unit may have blown from being overloaded or faulty. Should be an easy fix at a trusted electronic service place.I am not sure if your system has a manual reset button underneath or on back, but you could look for a tiny hole with reset on it or a red button. It may save you a trip to the doc.
Nov 11, 2007 | Marantz SR4500 Receiver
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
buttons
Aug 09, 2014 | Marantz SR5007 Home Theater AV Receiver
My marantz sr5004 is flashing the standby light and wont switch on
Switch off the unit. Then hold down Sorround, Exit, Memory & Clear buttons all together and then switch on the power. This should work.
Apr 22, 2012 | Marantz SR5004
We have a Marantz sr4500, everytime we put it on it makes a Zzzzzz sound and then it turns off with a loud "buk" sound and shows protect on the amp's screen, after few seconds the amp turns...
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.In this case I think that some capacitors are faulty as when the set is put on it charges on to make the amplifier work. Possible fault in the protect circuit or preamp.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
May 11, 2011 | Marantz SR4500 Receiver
How do you program it without the remote
You can do it by using the arrow keys at the front panel.Study the user manual before that.
Dec 06, 2010 | Marantz SR4500 Receiver
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Obstructed ventilation holes?marantz sr4500
if your amp doesnt have air vent fins on the sides you shouldnt have any problems with overheating
Dec 29, 2007 | Marantz SR4500 Receiver
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
