Hi
if you are face any problem epson printer related you can visit our site and get the more information.https://www.epsonprintersupport247.com/fix-epson-printer-error-code-0xe3/
SOURCE: epson stylus photo heeds reset on mac
Hi, this means your printer needs a maintenance service from epson, ie the printer has met its end of life unless you want to pay epson £75+vat for the maintenance call.
Happy New Year
John
SOURCE: blinking red lights
I have a canon s630 and the yellow light blinks 7 times and green once, what is causing this and can i reset this printer?
SOURCE: my printer epson r230 is not working. the two red
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
SOURCE: Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Testimonial: "Thank you. I was on the phone with Lexmark a whole hour last night and they couldn't fix it. This corrected the problem immediately! You are a Wiz"
SOURCE: Epson R2400 paper and ink lights blinking red. Ink
You can easy download FREE reset utility - www.epsomreset.com and reset the waste ink counter for many models
