Go into set up tv air and channel search on digital
SOURCE: Telefunken analogue color TV model
As you said, its an analog model tv so it doesn't have Audio-Video connectors to hook up set top box.
Sorry.
SOURCE: No antenna reception with digital converter box.
Hello Faznmc,
I have found that with an ordinary antenna connected to the converter box it can receive nearly all channels, however I have run into cases where I had to use an amplified TV antenna to pick up signals. I have started telling folks that when they install their converter boxes to try to use the plain old rabbit ears antenna, but if that does not work, use an amplified antenna, and that usually does the trick.
I hope this helps
Thank you,
Shuttle83
SOURCE: Sony WEGA KD-32DX50 U Tuning problem
This is answered on the sony support pages see
http://www.sony.co.uk/section/contact
and then enter 're-tune digital channels' in the search by keyword box for the explanation.
It basically needs a software upgrade which will be downloaded free if you've still got a freeview channel - but if you've lost them all you'll need help - anyway it's all explained by sony.
SOURCE: How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
SOURCE: LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
