You can try to find the O.E.M. part, take one from an old junked light, or find a generic switch from the hardware store and make it work. You diagnosed the problem already. You could replace it with a regular (DC) switch if you normally "lock" it on most of the time. Miniature Pushbutton Switches
You might just consider replacing it, as it seems there is risk for fire with this model. 1 000 000 Candlelight Spotlight fire
Set time with the ccr30ii turned off. Use Set Time button and tune/skip control arrows. Use Time Set to cycle through the hours and minutes. Do the same for setting alarms. Not an easy item to get info on. It is NOTHING like the RCA model above. It is a touch control AM/FM radio alarm with two iPod docks which can be switched to play from each. The radio tends to fail It is disabled when iPods are connected, so it may be something to do with the circuitry that does this that stops the radio working. A good item which can be bought very cheaply now.
I don't think the normal users manual would help you. (sears says to contact them for the availability of it). You need a repair manual. I will continue research and probably repost, but in the meantime, this is all I have found on the "mower" so far. I am going after the engine now.
Lisa set the time required on the Drying time control right hand side for high temperature up to 130 mins max and left hand side for low temperature up to 90 mins max. Now set the washer timed dial to the drying emblem (3 vertical wavy lines) next to position 8, then finally you need to push in all 4 control buttons on the left of the thermostat. It should now work according to my wife.
Dave
Looks like your speed wire control went bad, this is just a rheostat that with normal use the coil will wear off and lose contact. Don't know the year of your machine but this item it is an inexpensive item to replace and you can do it yourself. Part number is MIL 000101 and the cost is around $150.00. If you need the owners manual let me know.
