Tools & Hardware - Others Logo
M
Mafana Xolani Posted on May 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a cover page for my assignment - Omega Tools & Hardware - Others
goneforever.
Level 3:
Top Expert:
  • Master 14,531 Answers
  • Posted on May 23, 2019
goneforever.
Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263733
Points
66315
How to program the page button
Can you please be a little more specific? Are you referring to assigning the paging feature to a button on the phone or programming the actions the system performs when you press the existing paging button on the phone? Normally, when you press the predefined paging button on this phone the system prompts you to select where your paging output goes. Depending on how your system was set up it may ask you to select "set", meaning when you select this soft-key the system will sound a short alert tone through all of the speakers in all of the phones connected to the system then allow you to talk through all of the phone set speakers. The other option is to select a soft-key that directs the output of the paging to an external PA system that is connected to the NAM through a punchblock connection. You can usually also select "both" which directs the output through the phone sets and the PA system. I am not certain what, if any system programming might be involved - I am fairly certain that if your system has not been connected to a PA system the paging function is just available to output through the phone set speakers. If your phones have no buttons assigned to the page feature then you'll need to refer to the system programming procedures to find out which feature code is assigned to paging and then access it by pressing FEATURE + the paging code or assigning the paging feature code to an unused button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
2answers
How to assign trunk lines on NEC SL1000 Keyphone System?
Try posting here:
http://www.tek-tips.com/threadminder.cfm?pid=937&page=1
How do i assign a paging group
By default, phones are all in Page group 1. In system programs 6xx (603,650 etc) you can change the assignment.
Carl
2answers
My hardwired computer gets on line but the other two wireless can't. I've reset the router several times but no luck. Checked all the connection still no luck.
Check if the router is assigning IP addresses to the Wireless devices. Also se if you hard-wired desktop has been assigned an IP address manually. Else try to assign IP's to wireless devices manually (Depends on your setup)
Please rate if helpful.
Thanks
2answers
Need an installation and setup guide for tmc soho m4810.
you have to assign an ext to the phone.Press Program and extension button to assign it to an extension.
all phones have to have different assigned ext (obviously)...
To cancel stored extension(to change) Press program, press PAGE twice, press mute.
I need the users guide!!! have quite a few install and set up guides - I just need the users guide!!! need to change time and other things!!!
Please help...will trade...
1helpful
2answers
I have two optical inputs the one one the left works wellwith my dvd player. I tried plugging my satalite into the other optical input but it won't let me change the tv button to digital
Discovered, with help, that the manual actually did cover this. Around pages 20-21 described the way that you can set which inputs each of the OPT1/OPT2/COAX inputs get assigned to. Basically scroll through the different setup options on the remote till you find the settings for the OPT2 - in my case it was set to "Off" - which explains things. Just switched to TV and voila, worked great.
Top Omega Tools & Hardware - Others Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
goneforever.
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
