Yamaha Yamalube Outboard Oil Change Kit F200-F250 10W-30 Oil - check description Logo
A
Anonymous Posted on May 23, 2019
How many cylinders in a f25 four stroke yamaha
Danny
Level 2:
Habit-Forming:
Filmmaker:
Uploaded 5 video answers.
  • Expert 174 Answers
  • Posted on May 26, 2019
 Danny
Expert
Level 2:
Habit-Forming:
Filmmaker:
Answers
174
Questions
0
Helped
52459
Points
350
Your motor has 2 cylinders.
5 Related Answers
tombones
  • 3567 Answers
  • Posted on Mar 13, 2009
SOURCE: four wheeler back fires
If the motor has two carbs then balance the carbs. Balancing the carbs basically means being certain the slides on both carbs open up simultaneously. If one carb opens sooner than the other then it 'drives' the other carb and can cause the backfire. Other things can can cause a backfire but lets start here first.
Kerry
  • 137 Answers
  • Posted on Nov 18, 2009
SOURCE: explain the four stroke cycleof a three cylinder
It is the same as any other engine no matter how many cylinders there are. . A 4 stroke engine has the intake stroke then compression then ignition then exhaust.(piston goes down for intake stroke,then up for compression then it fires the fuel air mixture from the intake stroke and that pushes the piston back down and on its way back up the exhaust valve opens for the exhaust stroke)
Quinn Kessler
  • 85 Answers
  • Posted on Dec 04, 2009
SOURCE: yamaha 225 four stroke overheating
If the engine wasn't overheating before the thermostat was replaced it could be a problem with the installation or possibly the coolant levels weren't refilled enough or at all, also if the leg was rebuilt their may be a problem with the way it was done and the engine is now working too hard to turn the prop although I think that this is unlikely. First thing is to check the coolant levels and if they are fine then you need to ensure that the water pump is circulating the coolant. If both of those check out fine then I would think that the thermostat installation is suspect and should be checked.
Anonymous
  • 7 Answers
  • Posted on Apr 04, 2010
SOURCE: wont start
also check the jetting is set properly for weather ect, check for flooding, as mentioned check vavle clearance, also fiddle with the idle knob and fuel mixture screw(this is annoying to get to as its under the carb) and im asuming you already know the starting procedure for the 426.
Anonymous
  • 155 Answers
  • Posted on Apr 08, 2010
SOURCE: could anyone tell me how to build a two stroke
this may sound like i'm a smart head ,,but a muffler is a muffler,, the pipe with a slip on is fine
What is bore and stroke of my 50cc derbi
Visit two-stroke engine a four stroke one cylinder to cylinder four cylinders if you need to measure the borer and the bike is a part just use calipers or just look it up online
1helpful
Model identification of Yamaha 15 four stroke
YAMAHA MODEL
YEAR GUIDE
EXAMPLE:
"F15MLHW" would
be a
Four Stroke, 15 HP,
Manual Tilt/
Manual Start, 20"
Shaft, Tiller Steer,
1998 model
THESE CODES ARE
GOOD FOR USA
MODELS ONLY
If you are outside
the USA we can
only help if you
have original
Yamaha part
numbers.
Please contact
Yamaha in your
area to buy a parts
catalog for your
motor.
Jan 27, 2013 • Boating
Hi guys, my bike keeps cutting out if i put lights on or press the brakes front or rear. bike starts and idles fine. totally stumped and any help would be great
  1. Yamaha Fazer Engine and Transmission
    • The 1998 Fazer is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with displacement measuring 36.55-cubic inches. This motor generates 95 horsepower at 11,500 rpm and 45.0 foot-pounds of torque at 9,500 rpm. It has a six-speed transmission and a liquid cooling system. The 1998 Fazer has a top speed of 139.8 mph.
    Yamaha Fazer Brakes, Weight and Fuel Capacity
    • The 1998 Fazer has dual-disc front brakes and single-disc rear brakes. It has a seat height of 31.1 inches at its lowest setting and a dry weight totaling 416.7 lbs. The Fazer has and electric starter and a fuel capacity of 4.75 gallons.
    Yamaha Thundercat Engine and Transmission
    • The 1998 Thundercat is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with a displacement of 36.55-cubic inches. It generates 100.00 horsepower at 11,500 rpm and 48.7 foot-pounds of torque at 9,500 rpm. The Thundercat has a six-speed transmission and a liquid cooling system.
    Yamaha Thundercat Brakes, Weight and Capacity
    • The Thundercat has dual-disc front brakes and single-disc rear brakes. It has a dry weight of 412.3 lbs. and a seat height of 31.3 inches at its lowest setting. The 1998 Thundercat has an electric starter, a 5.0-gallon fuel capacity and a top speed of 158.4 mph.
2003 yamaha yz450f valve adj specs
The 2003 Yamaha YZ450F is a big-bore, air-cooled two-stroke motorcycle. It was first introduced in 2001 and was the replacement for the 2000 model year YZ450F. The engine displacement has remained at 450cc since then. It uses an overhead camshaft with four valves per cylinder and a 4 valve/cylinder head configuration to create power output of 35 PS (29 kW) @ 8500 rpm and 25 lb·ft (35 Nm) @ 7200 rpm with a compression ratio of 9.7:1.
1helpful
2answers
I have a yzf 426 yamaha. What fuel do I put in it? What oil do I put in it? Is it a 4 stroke motor bike? Please help me - Thankyou!
Model: Yamaha YZ 426 F Year: 2002 Category: Cross / motocross Rating: 71.6 out of 100 Engine and transmission Displacement: 426.00 ccm (25.99 cubic inches) Engine type: Single cylinder, four-stroke Compression: 12.5:1 Bore x stroke: 95.0 x 60.1 mm (3.7 x 2.4 inches) Valves per cylinder: 5 Fuel control: DOHC Cooling system: Liquid Chassis, suspension, brakes and wheels Front suspensiontravel: 300 mm (11.8 inches) Rear suspension travel: 315 mm (12.4 inches) Front tyre dimensions: 80/100-21 Rear tyre dimensions: 110/90-19 Front brakes: Single disc Front brakes diameter: 250 mm (9.8 inches) Rear brakes: Single disc Rear brakes diameter: 240 mm (9.4 inches) Physical measures and capacities Dry weight: 105.0 kg (231.5 pounds) Seat height: 998 mm (39.3 inches) If adjustable, lowest setting. Overall height: 1,303 mm (51.3 inches) Overall length: 2,171 mm (85.5 inches) Overall width: 827 mm (32.6 inches) Ground clearance: 375 mm (14.8 inches) Wheelbase: 1,490 mm (58.7 inches)
1helpful
Xs750 what is the firing order
There is no firing order. Your bike has a coil that fires on both the compression stroke and the exhaust stroke (also called a wasted spark). Therefore either plug wire can go on either cylinder and the bike should run the same.On four cylinder bikes this meant that you could run four plugs using only two coils and two sets of points instead of four coils and four points.If the bike is running poorly try new spark plugs and new spark plug caps first(start with the cheap stuff). Next check the actual coil and pulse pick up or points. You may have to replace the coil only because the wires are cracked shorting.
2answers
Explain the four stroke cycleof a three cylinder
Is this a quiz? Each cylinder contains one piston that takes four strokes to coplete a a full cycle. the intake-down,compression-up, power-down, exhaust -up.
A two stroke has up and down only . Compression and power Now, I thik you really meant the firing order. I'm not sure but Would make sense 2-3-2?
3helpful
Would like to know the gas tank capacity for a 1996 xvz 1300 a royal star yamaha cycle, and tire size please
YAMAHA ROYAL STAR Engine Type: 1294cc liquid cooled 70 degree DOHC V-four, four valves per cylinder
Bore and Stroke: 79 x 66mm
Compression Ratio: 10.1:1
Carburetor: 4 x 28mm Mikuni CV
Transmission: 5-speed
Wheelbase: 66.7 in.
Dry Weight: 701 lbs.
Tires: Front; 150/80V16 Rear; 150/90V15
Forks: 43mm Kayaba
Rear Suspension: Kayaba mono-shock with adjustable preload
Brakes: 298mm dual front discs with dual-piston calipers; 320mm rear disc with dual-piston calipers
Seat Height: 28.3 in.
Fuel Capacity: 4.8 gallons
1helpful
2answers
Do i have to mix 2 stroke oil on the gas for the 4 stroke bikes or just add regular gas on the tank? if is what is the scale for the mix?
DO NOT mix oil in the gas on your four stroke engine. You will foul the spark plug(s), build up deposits on the valves and head, and make a smokey, smelly mess. A two stroke engine uses the fuel/oil mix to lubricate the engine before being used as fuel. A four stroke engine has a separate lubrication system and does not normally burn any oil. As the name implies, a two stroke engine works in two strokes. The first stroke is downward, where the fuel/oil mix and air are drawn into the cylinder. The momentum from the crankshaft counterbalance or force from the other cylinder(s) drive the piston back up compressing the mix, and the spark plug sparks at or slightly before the top of the stroke. The rapid combustion of the fuel/oil/air mix drives the piston down, which is the power stroke, and then the cycle starts all over again. A four stroke engine has an intake stroke down taking in the fuel/air mix, a compression stroke up, a power stroke down as the fuel/air mix is ignited at or before the top of the stroke, and a exhaust stroke up before starting all over again. A four stroke is much cleaner and more reliable than a two stroke, but it is heavier and has less torque. A two stroke engine is much lighter and has more torque, but takes more maintenance.
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
