If you mean how do you access your router from your phone so you can get at the settings pages, you will need to get on your router from a PC or laptop connected directly to it and enable the remote access option on you router.
N.B. This will make your routers pages accessible via the internet so make sure that your access passwords are strong and that you have security, enabled on you router to prevent anyone getting access and changing your settings.
If you cannot access your router because you have forgotten the password you will need to locate the reset hole and use a pin to reset your router back to the factory defaults, if you can advise what the make and model of your router is, I can give you more advice on doing this
If
all else fails, you can reset the router, this different than simply
restarting it. You will need a pin or paperclip to press the reset
button usually found on the back or sometimes on the bottom of router.
PLEASE
NOTE: Resetting the router will delete all current settings including
securtiy and reset them to their factory default settings.
But
this will isloate any issues that may be associated with your current
settings including security. You can reconfigure your router with the
settings you perfer after determining that the issue is with the router
or not.
his applies only to third-party routers. Apple AirPort products do not have a setting to enable or disable WMM.
WMM must be enabled for devices to connect. Disabling WMM on your wireless router can prevent the following Apple products from connecting to an 802.11n Wi-Fi network:
If you are unable to connect to an 802.11n Wi-Fi network on any of these devices, check to ensure that WMM is enabled and configured correctly on your wireless router. If you require additional assistance, please contact your router manufacturer.
