SOURCE: Bigpond Email Customer Service Call 1-805-225-6690 We are 24 Hour Available Call Now for Help
Sorry you are having this problem,
Sounds to me like your eMail client configuration is incorrect...
Is this a new problem where you were able to send an receive mail no problem before and now this ?
I suspect it is a new set-up.
It looks like you entered your eMail address where the software was asking for the address of the SMTP mail server...
Port 465 is for a secure SMTP Server.
Normally, the SMTP server port is 25 or 26.
Have you modified your eMail settings lately ?
Or maybe it works well from home but not when you are on another network....
Bigpond has implemented some security on their network, see here:
http://bigpond.custhelp.com/cgi-bin/bigpond.cfg/php/enduser/std_adp.php?p_faqid=5562
So, when you are connected to the bigpond network, you must use their SMTP server:
mail.bigpond.com
Otherwise, it will reject the connection.
When you are away from the bigpond network, you might have to ask your host or whoever, who provides the highspeed internet access ?
and then google for their smtp server,
ex: securenet.net smtp server
earthlink smtp server
you will quickly and easily find this server and all you have to do is enter it temporarily into your SMTP server field in your eMail client settings
making sure to set it back to bigpond once you are back home..
THis should get you back on your way again.
SOURCE: I cannot delete a wrong email address from Windows
Click on the contact icon on the toolbar, The Doubl Click onthe contact to open the properties for the contact you want to change, click on the Name and E-mail tab, then select the e-mail address below, at the right, select Edit, and that will allow you to change the address to the correct one. and select ok. Your change shou;ld be accepted.
SOURCE: I cant sign in to my yahoo mail service this
[email protected]: is this the ID you forgot the password... no problem click here
Reset your password from this site by your alternate email(hotmail) address (**********@h******.c**.au)
please follow the screenshot... member= your hotmail login ID
SOURCE: Email Address Problems
You must enter a DNS server on the "Network Settings > TCP / IP" page. If you're unsure of it, try copying your default gateway.
